New cards button not working for automation
Toggling an automation does not trigger it. It changes it from enabled to disabled or vice-versa.
What you need is:
show_name: true
show_icon: true
type: button
entity: automation.master_bedroom_close
tap_action:
  action: call_service
  service: automation.trigger
    entity_id: automation.master_bedroom_close
    skip_condition: true
You should be aware that manually triggering an automation bypasses any conditions and just runs the actions unless you set skip_condition: false
Additionally if the only thing that triggers your automation is this button you should use a script instead.
The script syntax is exactly the same as for automation actions.
Finally, please format your pasted config in future: https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371#oneone-format-it-properly-16
