Hey, everything looks pretty good. Maybe the still image is not coming through okay. Maybe lower the confidence really low to see if it gets a hit on anything.
Try raising your confidence. It’s not perfect by any means. You could also try another model.
Even higher it was missing the people, like it was getting the wrong image some how.
So depending on the detector, it resizes to 300x300. If the aspect is very wide, maybe it’s distorting the image too much. Eventually I want to make the add-on crop the global detection area. I haven’t had time to work on it in a bit. Life getting in the way of my hobbies. lol
It’s like it’s returning the correct detection boxes, but the wrong image behind them, if that makes sense at all.
I think its just detecting stuff it thinks is people, the confidence doesn’t look very high. (40%) etc This happened a lot with mine till i switched to tesnorflow and upped the confidence quite a bit.
Yah, I agree with @BlazeYaSmartHome, tensorflow lite mobilenet SSD vs say inception on tensorflow is night and day difference in accuracy
I’m using the default detector:
detectors:
- name: default
type: tflite
modelFile: models/coco_ssd_mobilenet_v1_1.0_quant.tflite
labelFile: models/coco_labels0.txt
numThreads: 4
numConcurrent: 4
I’m game for suggestions
Thank you.
hello, I bought a google coral usb, I’m still waiting to receive it, right now I’m using the hassio addon without acceleration, when I want to use google coral with the addon, would it just change the line “hwAccel” to true? Or would I have to do something else? Regards, and thanks for your work
You need to use a model that’s designed for the edge tpu. You can download them here: https://coral.ai/models/
Thanks for answer so quickly, where I should copy this models?
Which model will better for person recognized?
I’m using hassio on docker
Can I put the new models in the directory that I want or has to be in the default one? Because in my system there is no doods folder inside the opt or share folder
For example:
/config/www/models/xxx.tflite
Or
/local/models/xxx.tflite
Hey @pollinolas check out the docs for the hassio addon here: https://github.com/snowzach/hassio-addons/tree/master/doods
You can put them in /share/doods and there are configuration examples on that page.
May I ask how you are doing this? I have one of the same cams and a few others that are also dahua.
I actually have BI, but the pullpoint subscription isn’t working for them…only my hikvision cams.
So if you have a way to go straight from the cam to HA that would be great.
I’m using this python program that logs Dahua camera events to MQTT:
Thanks for the lead. I followed that link and a couple mins later ended up at the amcrest component which works for dahua cams. Well two types of mine that I tried anyway.
For anyone else interested it is here:
Okay I’m no programmer, but I’m trying to learn here. I just started today and got it working using the hassio (.103.2) addon with all default settings. Yay!
Thing is my wife’s beloved hydrangea shows up as a person in one cam and a car in the other. Same plant too! Just different angles from two different cams. Overall not very accurate.
So how do I replace a model? Looking at the install docs I see:
"name": "inception",
"type": "tensorflow",
"modelFile": "/share/doods/faster_rcnn_inception_v2_coco_2018_01_28.pb",
"labelFile": "/share/doods/coco_labels1.txt",
"numThreads": 1,
"numConcurrent": 1,
"hwAccel": false
yet when I download one from here (I’ve tried a few…maybe I’m getting wrong kind)
https://github.com/tensorflow/models/blob/3635527dc66cdfe7270e5b3086858db7307df8a3/research/object_detection/g3doc/detection_model_zoo.md
they don’t have the same file with it after extracting it. There is a .pb, but the name is different and no labels file.
I’ve even tried the one linked by the OP in post 104: New Custom Compontent - Image Processing - Object Detection - DOODS
Any suggestions on what I’m doing wrong?
hello, I already have it working with google coral, in my case the directory was in :
./var/lib/docker/overlay2/ce6cdb5a533fd7b056e98cd6e2b004ffae2d249e7bc92c7aef17c18a91bdacdb/diff/opt/doods/models/
I had to search the .tflite file to find the estrange directory
