I have now tried to run docker exec -it -e LOGGER_LEVEL='debug' addon_d5f40609_doods bash
, but that doesn’t really change anything. Still not getting debug entries in the log. Can I set the environment variable any other way?
I opened the DOODS addon container in Portainer and added an environment variable LOGGER_LEVEL set to debug. Let Portainer replace the existing container with the new one, and then checked the container log and am seeing the increased logging. Same log should be what you see if you check the log for the DOODS addon in HA.
Thanks! Took a bit to figure out what you meant, but I think I did it.
The full log can be found here: https://pastebin.com/J3D3rjwf. I have included a snippet below, since this the log looks like a repeating pattern.
I haven’t changed my HA config from from the last one. Something I noticed is the WARN entry that talks about a missing label. I didn’t see that one when I checked my logs yesterday.
2021-03-24T05:24:25.399Z DEBUG tensorflow/tensorflow.go:207 Detection {"package": "detector.tensorflow", "name": "tensorflow", "scores": [0.985551, 0.8421051, 0.8397212, 0.55919105, 0.48267362, 0.43471223, 0.42716938, 0.3822009, 0.35555902, 0.34410286, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], "classes": [62, 62, 63, 62, 44, 67, 44, 67, 84, 63, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1], "locations": [[0.25625303,0.4646785,0.5884545,0.6170678],[0.36208946,0.75828826,0.63467395,0.8442949],[0.36922437,0.010421276,0.9797347,0.31248572],[0.36866656,0.8316601,0.6364439,0.9090653],[0.5025996,0.29972798,0.59729755,0.31670398],[0.42949525,0.24584639,0.8206326,0.4941054],[0.5069038,0.30609703,0.597768,0.32229543],[0.33750704,0.76770705,0.61444306,0.9121719],[0.1173751,0.39867806,0.3617446,0.51284426],[0.31654668,0.0407618,0.6584834,0.38955843],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0]], "count": 10}
2021-03-24T05:24:25.399Z WARN tensorflow/tensorflow.go:214 Missing label {"package": "detector.tensorflow", "name": "tensorflow", "index": 84}
2021-03-24T05:24:25.399Z INFO tensorflow/tensorflow.go:228 Detection Complete {"package": "detector.tensorflow", "name": "tensorflow", "id": "", "duration": 0.350108723, "detections": 10}
2021-03-24T05:24:25.400Z INFO server/server.go:139 HTTP Request {"status": 200, "took": 0.35902036, "request": "/detect", "method": "POST", "package": "server.request", "request-id": "d5f40609-doods/MrL9FpIU2M-000003", "remote": "192.168.1.252:58140"}
The documentation on the model labels/classes is pretty bad so that’s what I’ve pieced together…
This is your scores: "scores": [0.985551, 0.8421051, 0.8397212, 0.55919105.....
from 0-1 with 1 being 100% match
This is your classes: "classes": [62, 62, 63, 62, 44, 67, 44, 67, ....
which cooresponds to a class/label in the file. I don’t even see a person in that match. Mostly just tv and toilet I think lol. Does that seem right?
Here are the labels and the classes coorespond to the line numbers: https://raw.githubusercontent.com/amikelive/coco-labels/master/coco-labels-2014_2017.txt
Well, there is no toilet in the picture, and you barely see the TV. It looks at the TV from the top left, so you only see a part of the bezel, none of the screen. Really weird!
Stupid question, i have tried an aqara camera connected to homekit controller integration, dont think camera is supported and its super laggy. But anyways its just for testing.
Got DOODS up and running and made a basic automation
binary sensor -> on -> call image processing (dont know if this is needed) send a image to phone.
However how can i make this smarter, so i can set a title cat detected, and human detected, instead of just motion detected?
hI guys,
can someone please help.
I’ve set up a camera and I’m trying to track just my driveway. as you can see it see my wifes car and reports 1
yet on the next scan it say’s there are zero cars , then later shows 1 car again
image_processing:
- platform: doods
scan_interval: 5
url: "http://10.0.0.9:8080"
detector: default
source:
- entity_id: camera.embedded_net_dvr_profilename009
file_out:
- "/config/www/sensor_scripts/{{ camera_entity.split('.')[1] }}_latest.jpg"
# - "/config/www/sensor_scripts/{{ camera_entity.split('.')[1] }}_{{ now().strftime('%Y%m%d_%H%M%S') }}.jpg"
- "/config/www/sensor_scripts/{{ camera_entity.split('.')[1] }}_.jpg"
confidence: 60
area:
top: 0.09
left: 0.17
# The entire detection must be inside this box
# covers: true
labels:
- name: person
confidence: 40
# area:
- name: car
confidence: 50
- truck
what am I doing wrong?
I would like to use the detection as a automation trigger
Does anyone know how to take multiple snapshots (say, 5 within 5 seconds), run them through DOODS and then email them? Thanks!
Hi, I’m quite late to this but just can not get the home assistant image processing to connect to doods addon. As I understand the problem is that I already have some addons that depend on port 8080. Sadly if I change the port on this addon configuration as well as the home assistant configuration I get the error “connection refused”
Sadly changing the port on other addons also not work without errors. Is there something I’m missing here?
The log with changed port. Already tried a lot of others but only on 8080 I get ip:8080/detectors webpage still with error HTTP Status 404 – Not Found but that’s way better than nothing at all on all other ports.
Logger: homeassistant.components.image_processing
Source: components/doods/image_processing.py:83
Integration: Image processing (documentation, issues)
First occurred: April 3, 2021, 11:52:23 PM (1 occurrences)
Last logged: April 3, 2021, 11:52:23 PM
Error while setting up doods platform for image_processing
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 169, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 96, in create_connection
raise err
File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 86, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 234, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/usr/local/lib/python3.8/http/client.py", line 1255, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1301, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1250, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1010, in _send_output
self.send(msg)
File "/usr/local/lib/python3.8/http/client.py", line 950, in send
self.connect()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 200, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 181, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f626044a760>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 573, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.20', port=8765): Max retries exceeded with url: /detectors (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f626044a760>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 200, in _async_setup_platform
await asyncio.shield(task)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/doods/image_processing.py", line 83, in setup_platform
doods = PyDOODS(url, auth_key, timeout)
File "/usr/local/lib/python3.8/site-packages/pydoods/__init__.py", line 13, in __init__
self.get_detectors()
File "/usr/local/lib/python3.8/site-packages/pydoods/__init__.py", line 20, in get_detectors
response = requests.get(self.url + "/detectors", **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.20', port=8765): Max retries exceeded with url: /detectors (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f626044a760>: Failed to establish a new connection: [Errno 111] Connection refused'))
Is there anything I can try to fix this?
Do anybody know if there’s a way to make a non-horizontal top area line? so it is one percentage in the left and another in the right side?
Anyone using DOODS for bird identification? I can’t seem to find a model that DOODS can use.
Ok, I have this crazy idea and I think I need a little help.
Home assistant/doods/node red; a motion sensor triggers a flow
in NR and when there is a person a photos is stored.
Using a state-node (msg.data.attributes.summary) and a switch-node it was pretty easy to do.
Now the next step; I would like to inspect the parameters of the
bounding box because, if the person is almost out of frame. I would
like to adjust the camera accordingly (PTZ). So that it ‘follows’
How to get these bounding box parameters?
Hope someone smarter than me can get me on track.
Thanks in advance.
Regards,
NongSung
EDIT. Disregard.
Im new here and trying to setup integration on hassio, on RPI4. I’ve installed DOODS using Hass.IO Repository for snowzach.
I have problem there is no any entity created for DOODS.:
Logs for DOODS looks like this:
2021-05-22T06:53:07.990+0200 INFO detector/detector.go:79 Configured Detector {"package": "detector", "name": "default", "type": "tflite", "model": "/opt/doods/models/coco_ssd_mobilenet_v1_1.0_quant.tflite", "labels": 80, "width": 300, "height": 300}
2021-05-22T06:53:09.323+0200 INFO detector/detector.go:79 Configured Detector {"package": "detector", "name": "tensorflow", "type": "tensorflow", "model": "/opt/doods/models/faster_rcnn_inception_v2_coco_2018_01_28.pb", "labels": 65, "width": -1, "height": -1}
2021-05-22T06:53:09.325+0200 INFO server/server.go:284 API Listening {"package": "server", "address": ":8080", "tls": false, "version": "v0.2.6-0-gb2a1c53-dirty"}
and my config is pretty simple:
image_processing:
- platform: doods
scan_interval: 10800
url: "http://192.168.8.108/:8080"
detector: default
source:
- entity_id: camera.drive_way
file_out:
- "/media/{{ camera_entity.split('.')[1] }}_latest.jpg"
- "/media/{{ camera_entity.split('.')[1] }}_{{ now().strftime('%Y%m%d_%H%M%S') }}.jpg"
confidence: 50
labels:
- name: person
confidence: 40
- car
- truck
Any idea what I’m do ing wrong?
Hello all,
I have just started with DOODS and am now running into a problem that I cannot solve. My server has multiple docker containers and without DOODS it ran like a charm, now I have implemented DOODS in HA and now after an hour the server crashes, I can’t even access the server with SSH anymore. To test I have moved DOODS to another server and set the scan_interval from 2 to 6 and then to 10. nothing works, anyone have an idea ??
I don’t think docker container should impact host greatly unless you a lot ridiculous resources to it and I would expect container crash first
Maybe it unrelated to docker and just show when add doods like out of storage.
You have many old container images and need remove unused?
Post docker run command or compose
Without investigating much… I’m betting you’re running out of memory and it’s starting to swap and destroys the machine. What kind of hardware are you running on?
Does anyone know if you can get the additional models when using the add-on or does this only work when you have manually installed in docker?
Also does that need to be ran inside the add-ons container?
Issue solved. There was a typo in line:
…not needed “/”
I know I’m late, but heres all the things the default model can detect.
- person
- bicycle
- car
- motorcycle
- airplane
- bus
- train
- truck
- boat
- traffic light
- fire hydrant
- stop sign
- parking meter
- bench
- bird
- cat
- dog
- horse
- sheep
- cow
- elephant
- bear
- zebra
- giraffe
- backpack
- umbrella
- handbag
- tie
- suitcase
- frisbee
- skis
- snowboard
- sports ball
- kite
- baseball bat
- baseball glove
- skateboard
- surfboard
- tennis racket
- bottle
- wine glass
- cup
- fork
- knife
- spoon
- bowl
- banana
- apple
- sandwich
- orange
- broccoli
- carrot
- hot dog
- pizza
- donut
- cake
- chair
- couch
- potted plant
- bed
- dining table
- toilet
- tv
- laptop
- mouse
- remote
- keyboard
- cell phone
- microwave
- oven
- toaster
- sink
- refrigerator
- book
- clock
- vase
- scissors
- teddy bear
- hair drier
- toothbrush
source: https://raw.githubusercontent.com/amikelive/coco-labels/master/coco-labels-2014_2017.txt
