Oh, and the HA Green is pi/arm 64 based?
SoC Rockchip RK3566 SoC with quad-core Arm Cortex-A55 CPU
CPU Frequency: 1.8 GHz
Any other model recommendations to try and increase efficiency, my primary use case is to recognize people, animals are a bonus… My use case triggers a single frame/pic after motion on a set of cameras and passes it off to DOODS to recognize people. I’d love if I could get that recognition sub-second, right now it seems to range from 4-9 seconds in my testing, although CPU and memory load seem fine.
Thanks. Any recommendations on models to target people, that are efficient and can work with DOODS on ARM? I just don’t know where to get started with other models. Thanks.
Just look on Ebay or whatever you use to find a cheap desktop with 16GB of ram and and Intel i5. Dell, HP and Lenovo all make them. Figure around 100$. I don’t know what the current cheap desktops are. Basically as companies replace them, there will be zillions of the same model. Maybe like this: Dell OptiPlex Mini Pc Desktop Computer Intel Core i5 16GB RAM 1TB HD Windows 10 | eBay
@snowzach , is it possible to set up multiple areas for the same object? if I add the same label twice, but with a different area, it only detects the second one. I tried removing the second zone and it gets detected in the first one ok. As a workaround, I set it to detect ,sheep" on the second area. It has a power confidence, but it works.
