ok, now also for first time i use websockets, also have the issue unavailable, never had this before on older api
but the automation a few post up did help me
i received a notification, “unavailable” from that automation
but what i CANTtell, is that it will be reconnected again , my automation did it
i recently upgraded to 86.1 from 84.2, so first time i use websockets
ok, now state unavailable 2 times in i think 5 min max
log here :
2019-01-25 09:59:33 ERROR (MainThread) [aioharmony.hubconnector] 192.168.0.21: Connection timed for hub 10271701
2019-01-25 10:09:46 ERROR (MainThread) [aioharmony.hubconnector] 192.168.0.21: Connection timed for hub 10271701
2019-01-25 10:09:49 ERROR (MainThread) [aioharmony.hubconnector] 192.168.0.21: Exception trying to establish web socket connection for hub 10271701: Cannot connect to host 192.168.0.21:8088 ssl:None [Host is unreachable]
ok, more and more websockets issues and unavailable states
going to load harmony as a custom component now from older release
The automation described a few posts above solved my problem, so it might be the easier thing to do, at least for now.
yes, automations works indeed, mine runs 10 times a day
i see on my remote now, i think when the automation runs … “pairing succesful”
never seen that before
it seems, that the automations-code will not work (for me)
- alias: Harmony monitor
platform: state
entity_id: remote.harmony_hub
to: 'unavailable'
- service: notify.pushbullet
data_template:
message: >
Harmony is {{ states('remote.harmony_hub') }}, trying to sync
- service: remote.harmony_sync
and i got this here
2021-03-03 12:46:16 ERROR (MainThread) [aioharmony.harmonyclient] 192.168.1.220: Unable to determine if XMPP is enabled: [Errno 113] Connect call failed (‘192.168.1.220’, 5222)
ps: i need XMPP enabled.
Just Google on how to enable XMPP.
Even with XMPP enabled the harmony Hub seems to loose contact regularly.
Also with the App on my Android phone. Crappy firmware in the Hub?
XMAPP is enabled. need it for my KODI (Logitech-Bluetooth-Connection)
hmm, i dont know.
Software
Remote: 4.15.280
Hub: 4.15.280
Nest: 1.1.4
HEOS: 1.1.7
Caseta: 1.3.2
RootCertificates: 1.1.10
Qivicon: 1.2.3
is the code for reconnect right?
platform: state
to: 'unavailable'
data_template:
message: >
Hi there!
I have HA and a Harmony Hub for a while and discovered I can use them together.
But I’m in the same path as some of you: my hub is marked as unavailable while the green led is bright and I can see it through some other services but in HA.
I set an automation as proposed above; I only receive the notifications but the call to sync does not seem to have any effect. Even launch manually through the DevTools, the service has no success in reconnecting the hub in HA.
I don’t understand the statement “load harmony as a custom component”. Could someone using that solution explain it briefly to me (and others in the same situation?)
Regards,
