I used this and just the last entry shows up in my entities. This is my lorex.yaml file
platform: ffmpeg
input: rtsp://USER:PWD@NVR_IP_ADD:554/cam/realmonitor?channel=6&subtype=1
platform: ffmpeg
input: rtsp://USER:PWD@NVR_IP_ADD:554/cam/realmonitor?channel=5&subtype=1
platform: ffmpeg
input: rtsp://USER:PWD@NVR_IP_ADD:554/cam/realmonitor?channel=4&subtype=1
platform: ffmpeg
input: rtsp://USER:PWD@NVR_IP_ADD:554/cam/realmonitor?channel=3&subtype=1
platform: ffmpeg
input: rtsp://USER:PWD@NVR_IP_ADD:554/cam/realmonitor?channel=1&subtype=1
platform: ffmpeg
input: rtsp://USER:PWD@NVR_IP_ADD:554/cam/realmonitor?channel=2&subtype=1
Any help would be deeply appreciated
I am in the same boat as you. Were you able to resolve it?
No, I only get one camera to work and its always the last one in my cameras. Yaml file.
jaltman056:
Do
Iāve even tried this in my config.yaml, but with the same results.
camera: !include lorex1.yaml
camera: !include lorex2.yaml
camera: !include lorex3.yaml
camera: !include lorex4.yaml
camera: !include lorex5.yaml
camera: !include lorex6.yaml
I conceded and I am finally using the Motion Eye Addon on HassIO
Thanks for your message. Iām going to give it a try. I have it loaded up but Iām in the middle of changing my entire network system. All new managed switches an AP access points.
Until I receive another need managed switch I do not have network access to my NVR.
Next week?
How does the motion eye work with Lorex?
Jon
I have access to the Lorex NVR again. I have been going over motion eye but I canāt figure out the setup for a camera. Can you post your settings?
In Motion Eye --> Add Camera
Camera Type: Network Camera
URL: rtsp://YOUR_NVR_IP_ADDRESS:554/cam/realmonitor?channel=1&subtype=1
Username: YOUR_NVR_UNAME
Password: YOUR_NVR_PWD
Once you type these in, it should take a moment or so to get the Camera feed populated as ā(unknown) RTSP/TCP Cameraā with a dropdown menu including the UDP option. I am using the TCP option and I added all my cameras using the same settings. I am using MotionEye 0.4.2 and latest HassIO (I think is 0.93) on Ubuntu Linux LTS18.04. I hope this helps you. Good Luck.
Thanks for the info.
I have got everything set as you did and from the web setup of motioneye everything works.
However, when I ticked the (iframe) left panel option I get an error.
I did some searching and found the yaml for iframe motioneye. It fails to load. It only showes me my IP for home assistant.
Blockquote
motioneye:
title: motionEye
icon: mdi:cctv
url: https://192.168.1.5:8765
Blockquote
HI @jaltman056
When you tried the config I gave you did, you monitor the logs and see something like this?
2019-06-03 20:31:59 WARNING (MainThread) [haffmpeg.tools] Error starting FFmpeg.
2019-06-03 20:33:01 ERROR (MainThread) [haffmpeg.core] FFmpeg fails [Errno 2] No such file or directory: āffmpegā: āffmpegā
I tried my camera setup on my X86 install running on Ubuntu and got this error Iām working through.
FYI, I found my answer hereā¦
Running Hassbian with 0.82, USB webcam plugged into rpi, shows as:
homeassistant@hassbian:~/c9workspace $ ls -ltrh /dev/video*
crw-rw---- 1 root video 81, 0 Nov 14 06:42 /dev/video0
All good. Wish to add to HA via ffmpeg , use config:
camera:
- platform: ffmpeg
input: -i /dev/video0
Get error:
FileNotFoundError: [Errno 2] No such file or directory: 'ffmpeg'
Any ideas?
Once I installed it my cameras are working now.
I am using Hass.IO , so for me, all I did was install the montion eye addon and flip the switch on to show it in the sidebar, and I refreshed the page and viola! I am glad to know that your cameras now work!
@jaltman056 , were you able to get this going without MotionEye?
Yes I did. Iām sorry I didnāt give you any feedback.
Motion Eye work very well with Lorex dvr. Too bad they just donāt support their products.
I see. No worries! Thank you.
@jaltman056 I finally got this working!
Hereās what I changed -
Added this to -
configuration.yaml
frontend:
javascript_version: latest
stream:
I have a cameras.yaml file, where I added these entries -
On my lovelace, I am using the following 6 cards -
camera: live
entity: camera.camera1
type: picture-entity
camera: live
entity: camera.camera2
camera: live
entity: camera.camera3
camera: live
entity: camera.camera4
camera: live
entity: camera.camera5
camera: live
entity: camera.camera6
dicko
(Martyn)
August 30, 2019, 9:47am
36
Hi
Did you put anything else anywhere as Im getting 2 errors
Component error: javascript_version - Integration javascript_version not found.
Component error: cameras - Integration cameras not found.
I have 2 Skyview cameras on a HView 8 channel DVR.
Do you know what Im doing wrong ?
Thanks in advance
Martyn
mihir2787
(Mihir)
August 30, 2019, 11:55am
37
ffmpeg:
ffmpeg_bin: /usr/bin/ffmpeg
frontend:
stream:
In my configuration.yaml
and the camera config is in my cameras.yaml file
dicko
(Martyn)
August 30, 2019, 9:08pm
38
Thanks that got rid of the errors.
Still no stream. I did notice that the names dont seem to match the cameras, is that correct ?
Where is the matching info for the camera names ie camera.camera1 as camera 1 is called cam1?
Martyn
mihir2787
(Mihir)
September 4, 2019, 2:40pm
39
Does the stream run locally on a vlc player with the same rtsp link?
dicko
(Martyn)
September 4, 2019, 10:11pm
40
Hi, got it working. I found another url input like below and it worked. I now have similar screenshots and streams working in HA as above.
rtsp://192.168.0.20:8554/user=USERNAME_password=PASSWORD_channel=2_stream=0.sdp?real_stream
Thanks for your help
