No drama, just figured a good script would save a lot of time for everyone in the community.
I am facing a similar issue when I use the new format because the entity is gone after I use the new format.
The old format (is working):
binary_sensor RF_Sensor_Peter:
- platform: mqtt
name: "RF Sensor Peter"
state_topic: "rflink/NewKaku-024726be"
value_template: "{{ value_json.SWITCH1 }}"
payload_on: "ON"
payload_off: "OFF"
qos: 1
switch RF_Switch_Peter:
- platform: mqtt
unique_id: house.rf.switch_peter
name: RF SWitch Peter
command_topic: "rflink/cmd"
payload_on: "10;NewKaku;024726be;1;ON;"
payload_off: "10;NewKaku;024726be;1;OFF;"
state_on: "ON"
state_off: "OFF"
optimistic: false
qos: 1
retain: false
The new format (entities does not show up anymore, old one deleted):
mqtt:
binary_sensor:
- name: "RF Sensor Peter"
payload_on: "ON"
payload_off: "OFF"
qos: 1
mqtt:
switch:
- unique_id: house.rf.switch_peter
state_on: "ON"
state_off: "OFF"
optimistic: false
qos: 1
retain: false
What am I missing?
Thanks in advance.
But there is almost no time to save.
it would likely take you longer to download and then run the script as it would to make the minimal change needed.
People are making this way harder than it needs to be. Hence → drama.
Because you can use two “mqtt:” keys. you only use one and put both “switch:” and “binary_sensor:” under the same one.
It works the same as any other top level domain in HA. You can only have one “switch:”, “sensor:”, “script:”, etc. (unless you use packages but that’s completely different).
if you want more than one then you need to add stuff to the keys as you did in your original config.
is different than:
switch:
but it’s still a switch key.
That simple … only once mqtt: and everything listed under there …
Thanks!!!
Hi
Same problem here. Nothing shows up. No errors in logs. No errors in configuration. And old format works correctly. I’m missing something or it’s still a work in progress.
5310
Your indentation is wrong.
mqtt:
switch:
- name: blah
You have
mqtt:
switch:
- name: blah
The entire config should look like:
mqtt:
switch:
- name: my switch 1
- name: my switch 2
- name: my switch 3
binary_sensor:
- name: my binary sensor 1
- name: my binary sensor 2
- name: my binary sensor 3
- name: my sensor 1
- name: my sensor 2
- name: my sensor 3
etc
Don’t repeat the mqtt
key.
mqtt:
binary_sensor:
payload_on: "ON"
payload_off: "OFF"
qos: 1
switch:
state_on: "ON"
state_off: "OFF"
optimistic: false
qos: 1
retain: false
That indentation is actually fine.
The only thing that really matters is that the indentation is consistent throughout the file.
You’ll need to give a bit more info than that for us to help you.
did you read the rest of the thread? Did you look at the docs for the new syntax?
you should post a large enough code snippet to show us what you tried.
Well, I put together a python script which converts to the new format, in case anyone is interested in using/improving it (could not figure out how to preserve comments).
Script:
import yaml
with open('configuration.yaml') as f:
config = yaml.load(f, Loader=yaml.BaseLoader)
def mq_conv(type, config):
config2 = {"mqtt":{type:[]}};
for sensor in config[type]:
if sensor['platform'] == "mqtt":
del sensor['platform']
config2["mqtt"][type].append(sensor)
return config2
if __name__ == '__main__':
print(yaml.dump(mq_conv('sensor',config)))
print(yaml.dump(mq_conv('binary_sensor',config)))
print(yaml.dump(mq_conv('switch',config)))
print(yaml.dump(mq_conv('climate',config)))
Worked ok for my purposes, and applied to the OP’s yaml:
mqtt:
- device_class: door
payload_off: frontdoorclosed
payload_on: frontdooropen
qos: '0'
state_topic: home/rfbridge/doorstate
name: Kitchen Door Main
payload_off: kitchendoorclosed
payload_on: kitchendooropen
qos: '0'
name: Kitchen Door L
payload_off: kitchendoorlclosed
payload_on: kitchendoorlopen
qos: '0'
- device_class: window
name: Kitchen Window L
payload_off: kitchenwindowclosed
payload_on: kitchenwindowopen
qos: '0'
name: Kitchen Window R
payload_off: kitchenwindowrclosed
payload_on: kitchenwindowropen
qos: '0'
name: Bedroom Door Left
payload_off: bedroomdoorleftclosed
payload_on: bedroomdoorleftopen
qos: '0'
name: Bedroom Door Right
payload_off: bedroomdoorrightclosed
payload_on: bedroomdoorrightopen
qos: '0'
- name: Fridge Door
payload_off: fridgedoorclosed
payload_on: fridgedooropen
qos: '0'
Cheers!
Does the script handle !included files from configuration.yaml? Including sub-directories of the includes and packages?
Sorry, no. Its very simplistic
then my opinion still stands that it’s easier to just take the literally 30 seconds it takes to make the change manually.
But good for you using it as a learning experience (if you did).
