Same problem here,
Someone mentioned 2,4/5 Ghz earlier. I do run Google Wifi which have the same SSID on both networks.
Same problem here,
Tried to put it on a separate 2,4 Ghz Network but it did not solve the problem.
Same problem here It used to work perfectly but now it shows “off” a lot even when on.
It will work for a day or two if I re-pair it.
Same issue here… connected via ethernet cable.
Connection to TV is ok initially after hard power reboot of tv, eventually disappears randomly.
Cannot rely on this integration sadly, the Ambilight (light) feature is useful when it works.
It seems to work so far. I also sometimes see the same behavior as others that it shows off while it’s on but the most annoying thing is that I cannot use the Andoird TV app on my mobile phone, when I open it immediately freaks out.
Anyone else seen this?
I tried to delete the integration but looks like it cannot be controlled anymore using mobile Android TV app, any solutions to restore this?
Same hete🥲
Still unreliable for me, it will work briefly if I restart the TV or delete and re-pair. but going from standby to on the state doesn’t change and on to standby
Still haven’t found a solution for getting the Android TV app to work again.
Anyone else does?
It doesn’t work for me either… two three hours and then it doesn’t go anymore
Did you guys solve it then?
hello, I have the pus7805. The TV is configured with api 6 however I did not see the PIN. Do I have to go to a specific menu or HDMI input? I use the Tv only with Apple TV- not smart TV or Satellite functions in use.
The TV responds to „switch off“ or „ambilight“ inputs via HA. However, when I switch it off via HA the integration will not work anymore. The television is offline and cannot switched on anymore.
What is wrong? Any ideas?
Djm193
If your TV does not allow you to still have a network or wifi connection in standby mode, it will not work. The TV will need to be switched on via IR, for example Broadlink.
I have installed the Phillips TV integration and appears to be working fine. From the remote I can select different sources, apps or TV channels.
How to I do this in a script? For example, I would like to use voice assist to select HDMI1
I have tried using the remote.send_command
but I am not sure what the data should be.
I have also tried media_player.select_source
but again without it working.
TIA
Any update on this problem?
After install it works for 1 or 2 days then the tv stays offline in the app.
