New platform RF iNELS (eLan)
Hello! After upgrading to version 1.10, elan2mqtt does not start. What can be done?
Hass Log :
20-05-12 21:32:13 ERROR (SyncWorker_4) [supervisor.docker] Can't create container from addon_964047f9_elan2mqtt: 404 Client Error: Not Found ("No such image: 964047f9/armv7-addon-elan2mqtt:1.10")
After a complete removal and reinstallation, everything worked.
Hi. i just wanted to say THANK YOU for this wonderful addon. works great (initial startup took quite som time but that is ok) and i can finnaly use something better than that stupud iNELS app.
THANX
well it was great while it lasted… was forced to migrate to RPI4 and to make a new install and since then the addon does not start with nothing more than “s6-overlay-suexec: fatal: can only run as pid 1” error in log…
i dont keep my hopes up but if you update the addon in the future i will sure test it out…
Dors this help?
well when installing localy and editing the config.yaml to include this init:false it did solve the error and addon successfully launched. setting it up right now but the stupid elko gateway keeps freezing…
but that is HW problem so thanks for the tip :slight_smile:
Please help.
Log from eLan MQTT:
what command line arguments need to be checked?
[2023-02-05 20:31:23,186] {socket_listener.py:304} ERROR - SOCKET LISTENER: Something went wrong. But don’t worry we will start over again.
File “/elan2mqtt-1.16.0/socket_listener.py”, line 302, in
asyncio.get_event_loop().run_until_complete(main())
File “/usr/local/lib/python3.10/asyncio/base_events.py”, line 646, in run_until_complete
return future.result()
File “/elan2mqtt-1.16.0/socket_listener.py”, line 143, in main
mqtt_cli.connect(mqtt_broker, 1883, 120)
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 914, in connect
return self.reconnect()
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 1044, in reconnect
sock = self._create_socket_connection()
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 3685, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File “/usr/local/lib/python3.10/socket.py”, line 845, in create_connection
raise err
File “/usr/local/lib/python3.10/socket.py”, line 833, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
[2023-02-05 20:31:23,187] {socket_listener.py:307} ERROR - But at first take some break. Sleeping for 5 s
[2023-02-05 20:31:28,191] {socket_listener.py:304} ERROR - SOCKET LISTENER: Something went wrong. But don’t worry we will start over again.
raise err
sock.connect(sa)
[2023-02-05 20:31:28,191] {socket_listener.py:307} ERROR - But at first take some break. Sleeping for 5 s
[2023-02-05 20:31:32,755] {main_worker.py:1067} ERROR - MAIN WORKER: Something went wrong. But don’t worry we will start over again.
File “/elan2mqtt-1.16.0/main_worker.py”, line 1065, in
File “/elan2mqtt-1.16.0/main_worker.py”, line 855, in main
raise err
sock.connect(sa)
[2023-02-05 20:31:32,755] {main_worker.py:1070} ERROR - But at first take some break. Sleeping for 10 s
[2023-02-05 20:31:33,198] {socket_listener.py:304} ERROR - SOCKET LISTENER: Something went wrong. But don’t worry we will start over again.
raise err
sock.connect(sa)
[2023-02-05 20:31:33,198] {socket_listener.py:307} ERROR - But at first take some break. Sleeping for 5 s
[2023-02-05 20:31:38,285] {socket_listener.py:304} ERROR - SOCKET LISTENER: Something went wrong. But don’t worry we will start over again.
raise err
sock.connect(sa)
[2023-02-05 20:31:38,286] {socket_listener.py:307} ERROR - But at first take some break. Sleeping for 5 s
“coonection refused” means that the eLan doesn’t accept connection from addon. Did you properly setup both addon and eLan?
In the addon IP address, username and password are the key settings
The eLAN IP address is 172.16.16.9
user: admin
password: elkoep
What’s wrong with me?
Hmm. Sorry. Just looked again at the error meesage. It is not an elan problem. It is mqtt problem.
Add-on can’t connect to your MQTT server. Check if it is accessible and username&password for mqtt is correct…
I am a complete beginner and therefore I ask how do I set up an MQTT server, please?
Sorry MQTT is out of scope of this thread. Please look into/follow HA documentation where this is described
or use one of video tutorials which could be found on youtube (for example Home Assistant MQTT Install and Setup - A Beginner's Guide - YouTube )
Ahoj,
nemáte odzkoušeno i s novou bránou eLAN-RF-103?
Mně se zatím spojení nedaří.
Help is needed. I am newbie to home assistant. An error occurs when installing the repository.
