Bieniu
(Maciek)
January 16, 2025, 2:30pm
143
Yes, only BLU Gateway Gen3 supports BLU TRV.
Push 3 times the button on the device.
Are there any Updates on the official integration?
Or can anyone post a link to an Step by Step Guide for the MQTT variant?
I’m not talented enough for this. Im used to plug and play from shelly devices.
BJeffrey
(Bryan Jeffrey)
January 17, 2025, 5:16pm
145
I have copied and pasted the code for my BluTrv but my editor is coming up with some errors on the action lines,I am not used to editing code and have tried a couple of things but they did not work any ideas?
action_topic: “shellyblugwg3-e4b3231668e0/status/blutrv:200” Value is not accepted. Valid Values:“cooling”, “Drying”, “fan”, “heating”, “idle”, “off”.
mqtt:
- climate:
unique_id: "F8:44:77:3A:C4:37"
current_temperature_topic: "shellyblugwg3-e4b3231668e0/status/blutrv:200"
current_temperature_template: "{{value_json.current_C}}"
max_temp: 30
min_temp: 4
temp_step: 0.1
temperature_state_topic: "shellyblugwg3-e4b3231668e0/status/blutrv:200"
temperature_state_template: "{{value_json.target_C}}"
temperature_command_template: "{{ {'id': 0, 'src': 'homeassistant', 'method': 'BluTRV.Call', 'params': {'id': 200, 'method': 'TRV.SetTarget', 'params': {'id': 0, 'target_C': value | round(1)}}} | to_json }}"
temperature_command_topic: "shellyblugwg3-e4b3231668e0/rpc"
mode_state_topic: "shellyblugwg3-e4b3231668e0/status/blutrv:200"
mode_state_template: "heat"
modes: ["heat"]
action_topic: "shellyblugwg3-e4b3231668e0/status/blutrv:200"
action_template: "{% if value_json.pos > 0 %}heating{% else %}idle{% endif %}"
availability:
- topic: "shellyblugwg3-e4b3231668e0/status/blutrv:200"
value_template: "{% if value_json.rpc %}online{% else %}offline{% endif %}"
device:
connections:
- - bluetooth
- F8:44:77:3A:C4:37
model: Shelly BLU TRV
model_id: SBTR-EU867E
manufacturer: Allterco Robotics
Hope this makes sense this is my first post.
@Bieniu what are you saying? I am not too versed with this stuff as well, but the action_topic
in your YAML provided here is exactly as the one in the question from @BJeffrey (and mine). I am not sure, if you are saying we need to change the YAML, of this indicates another error. Maybe you can add a sentence or two to help those struggling here?
Bieniu
(Maciek)
January 19, 2025, 12:36pm
148
I’m saying the documentation confirms the configuration is correct.
I figured out my issue: I downgraded from the 1.5.0-beta firmware after I saw some issues. That broke the integration for me. After upgrading again, everything looks schwifty now. Thanks for all your work @Bieniu !
Bieniu
(Maciek)
January 19, 2025, 12:50pm
150
Last configuration REQUIRES firmware 1.5.0 beta 1. There will be no HVAC action without this firmware.
Bieniu
(Maciek)
January 20, 2025, 11:06pm
151
PRs merged
home-assistant:dev
← chemelli74:chemelli74-shelly-trv
opened 10:28AM - 15 Oct 24 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Add support for new device: Shelly BLU TRV
Release notes: https://github.com/home-assistant-libs/aioshelly/releases/tag/12.3.0
changelog: https://github.com/home-assistant-libs/aioshelly/compare/12.2.0...12.3.0
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [x] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] I have followed the [perfect PR recommendations][perfect-pr]
- [x] The code has been formatted using Ruff (`ruff format homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [x] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [x] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
home-assistant:dev
← bieniu:shelly-blu-trv-valve-pos
opened 10:39PM - 09 Jan 25 UTC
## Breaking change
## Proposed change
This PR introduces new entities for Shelly BLU TRV:
- `battery` sensor
- `signal strength` sensor
- `valve position` sensor (only if automatic temperature control is disabled for the device)
- `calibration` binary sensor
- `external temperature` number entity
- `valve position` number entity (only if automatic temperature control is enabled for the device)
PR introduces the ability to select an entity class via `entity description`. I added a helper `get_entity_class` to easily select the appropriate class for the entity. In future changes we may migrate more entity descriptions to pass information about the appropriate entity class.
## Type of change
- [ ] Dependency upgrade
## Checklist
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
been reviewed.
and Shelly BLU TRV will be supported in HA 2025.2.
