I just received today 4 Sonoff SNZB-01 Model:WB01 and they are detected by my ZigBee Hub, yet they do not show up an temperature devices, they only display Power Levels.
I am assuming this is a new device yet to be seen, I exported the diag delow in the hopes this will help in getting HA to figure out the device type.
Thank you:
Diag Export:
“home_assistant”: {
“installation_type”: “Home Assistant OS”,
“version”: “2022.6.6”,
“dev”: false,
“hassio”: true,
“virtualenv”: false,
“python_version”: “3.9.12”,
“docker”: true,
“arch”: “x86_64”,
“timezone”: “America/New_York”,
“os_name”: “Linux”,
“os_version”: “5.15.45”,
“supervisor”: “2022.05.3”,
“host_os”: “Home Assistant OS 8.2”,
“docker_version”: “20.10.14”,
“chassis”: “vm”,
“run_as_root”: true
“custom_components”: {
“weatheralerts”: {
“version”: “0.1.4”,
“requirements”: []
“hacs”: {
“version”: “1.15.2”,
“requirements”: [
“aiofiles>=0.6.0”,
“aiogithubapi>=21.8.1”,
“awesomeversion>=21.2.2”,
“backoff>=1.10.0”,
“hacs_frontend==20210822172723”,
“queueman==0.5”
“reolink_dev”: {
“version”: “0.34”,
“requirements”: [
“reolink==0.0.39”
“integration_manifest”: {
“domain”: “zha”,
“name”: “Zigbee Home Automation”,
“config_flow”: true,
“documentation”: “Zigbee Home Automation - Home Assistant”,
“requirements”: [
“bellows==0.30.0”,
“pyserial==3.5”,
“pyserial-asyncio==0.6”,
“zha-quirks==0.0.75”,
“zigpy-deconz==0.16.0”,
“zigpy==0.45.1”,
“zigpy-xbee==0.14.0”,
“zigpy-zigate==0.7.4”,
“zigpy-znp==0.7.0”
“usb”: [
“vid”: “10C4”,
“pid”: “EA60”,
“description”: “2652”,
“known_devices”: [
“slae.sh cc2652rb stick”
“vid”: “10C4”,
“pid”: “EA60”,
“description”: “sonoffplus*”,
“known_devices”: [
“sonoff zigbee dongle plus”
“vid”: “10C4”,
“pid”: “EA60”,
“description”: “tubeszb”,
“known_devices”: [
“TubesZB Coordinator”
“vid”: “1A86”,
“pid”: “7523”,
“known_devices”: [
“vid”: “1A86”,
“pid”: “7523”,
“description”: “zigstar”,
“known_devices”: [
“ZigStar Coordinators”
“vid”: “1CF1”,
“pid”: “0030”,
“description”: “conbee”,
“known_devices”: [
“Conbee II”
“vid”: “10C4”,
“pid”: “8A2A”,
“description”: “zigbee”,
“known_devices”: [
“Nortek HUSBZB-1”
“vid”: “0403”,
“pid”: “6015”,
“description”: “zigate”,
“known_devices”: [
“ZiGate+”
“vid”: “10C4”,
“pid”: “EA60”,
“known_devices”: [
“ZiGate”
“vid”: “10C4”,
“pid”: “8B34”,
“description”: “bv 2010/10”,
“known_devices”: [
“Bitron Video AV2010/10”
“codeowners”: [
“@dmulcahey”,
“@adminiuga”
“zeroconf”: [
“type”: “_esphomelib._tcp.local.”,
“name”: “tube*”
“type”: “_zigate-zigbee-gateway._tcp.local.”,
“name”: “zigate”
“after_dependencies”: [
“usb”,
“zeroconf”
“iot_class”: “local_polling”,
“loggers”: [
“aiosqlite”,
“bellows”,
“crccheck”,
“pure_pcapy3”,
“zhaquirks”,
“zigpy”,
“zigpy_deconz”,
“zigpy_xbee”,
“zigpy_zigate”,
“zigpy_znp”
“is_built_in”: true
“data”: {
“ieee”: “REDACTED”,
“nwk”: 7003,
“manufacturer”: “eWeLink”,
“model”: “WB01”,
“name”: “eWeLink WB01”,
“quirk_applied”: true,
“quirk_class”: “zhaquirks.sonoff.button.SonoffButton”,
“manufacturer_code”: 0,
“power_source”: “Battery or Unknown”,
“lqi”: null,
“rssi”: null,
“last_seen”: “2022-06-20T15:16:24”,
“available”: true,
“device_type”: “EndDevice”,
“signature”: {
“node_descriptor”: “NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=0, maximum_buffer_size=80, maximum_incoming_transfer_size=160, server_mask=0, maximum_outgoing_transfer_size=160, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)”,
“endpoints”: {
“1”: {
“profile_id”: 260,
“device_type”: “0x0000”,
“in_clusters”: [
“0x0000”,
“0x0001”,
“0x0003”
“out_clusters”: [
“0x0003”,
“0x0006”
“entities”: [
“entity_id”: “button.temperature_sensor_19_identify”,
“entity_id”: “sensor.temperature_sensor_19_power”,
“neighbors”: [],
“endpoint_names”: [
“name”: “ON_OFF_SWITCH”
“user_given_name”: “temperature_sensor_19”,
“device_reg_id”: “a93885c14a80f935d49dfbf6f70ec53d”,
“area_id”: “hvac_2_ton”
This is also the Device Signature:
“endpoints”: {
“1”: {
“profile_id”: 260,
“in_clusters”: [
“0x0000”,
“0x0001”,
“0x0003”
“out_clusters”: [
“0x0003”,
“0x0006”
“model”: “WB01”,
“class”: “zhaquirks.sonoff.button.SonoffButton”
