Hi @sentur this isn’t implemented yet but I’m willing to do so. My idea is to add a service to allow setting the scan interval from automations. Will have a go when I get time.
In the meantime, if you need a faster update from 7-9am you could just set a higher SCAN_INTERVAL in your sensor config. You get 1000 API calls per day, so if you doubled your scan interval you would just use up your daily allowance at midday.
Since there is now a way to use lovelace with your cracking component I am putting this back in place. I have 3 bus routes all going from different places but all to the same destination. So the sensors are names xxxx_middlesbrough_1 _2 _3 which is fine, but I group 2 of them in the same stack as they are from the same location but different stops.
However the names of the stops swap around, so _1 is_2 etc? Is there another way to name them differently please? i.e. Middlesbrough_co Middlesbrough_po so they don’t switch around
For people using this component for train info, checkout the live map of trains moving on the network at https://www.map.signalbox.io/ The colour indicates whether the train is on time. I added to HA using an ipanel with:
