New User, Z-Stick/OpenZWave Issues
There’s a method for doing this from the lock itself using a code, but I’m at a client site so I don’t have it handy.
I think it’s called “Enroll” mode according the user guide, unless there’s another mode. It’s activated by entering the programming code then pressing “0”. Is that it?
That’s it.
Was away for the weekend. Think I finally got somewhere though. Don’t know how, but I see the lock in OpenZWave again and it says “ready”, but the value says “off.” Where can I go from here?
Try pressing the outside Schlage button and see if that wakes it up in the control panel.
I’ve tried a few different things here and there the last couple days, and think I can narrow it down to a network key mismatch somewhere. The only place I’ve edited mine is in my options.xml in the Openzwave directory. Below is the log entries when I try and highlight the lock and click “Add Node,” as well as my options.xml text.
OpenZWave Log Output:
2016-08-09 01:45:42.846 Detail, Queuing (Controller) Add Device
2016-08-09 01:45:42.846 Info, Add Device
2016-08-09 01:45:42.846 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x15, 0x64
2016-08-09 01:45:42.846 Detail, Notification: ControllerComand - Starting
2016-08-09 01:45:42.846 Info, Notification: ControllerCommand home c047e481 Event 1 Error 0
2016-08-09 01:45:42.846 Info, contrlr, Sending (Command) message (Callback ID=0x15, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x15, 0x64
2016-08-09 01:45:43.847 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2016-08-09 01:45:43.847 Detail, contrlr, Removing current message
2016-08-09 01:45:43.847 Detail, contrlr, Notification: Notification - TimeOut
2016-08-09 01:45:43.847 Info, Notification: Notification home c047e481 node 255 Timeout
2016-08-09 01:45:43.847 Detail, Notification: ControllerCommand - Error - Failed
2016-08-09 01:45:43.847 Info, Notification: ControllerCommand home c047e481 Event 3 Error 10
Options.xml (network key is obscured):
<?xml version="1.0" encoding="utf-8"?>
<!-- To be effective, this file should be placed in the user data folder specified in the Options::Create method -->
">http://code.google.com/p/open-zwave/'>
<Option name="logging" value="true" />
<Option name="Associate" value="true" />
<Option name="NotifyTransactions" value="false" />
<Option name="DriverMaxAttempts" value="5" />
<Option name="SaveConfiguration" value="true" />
<!-- <Option name="RetryTimeout" value="40000" /> -->
<!-- If you are using any Security Devices, you MUST set a network Key -->
<Option name="NetworkKey" value="0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00" />
<!-- Some Devices have a big UserCode Table, that can mean startup times
when refreshing Session Variables is very long (Especialy on Security
Devices) This option will make the UserCode CC stop on the first
"available" usercode slot rather than retrieve every one -->
<Option name="RefreshAllUserCodes" value="false" />
<Option name="ThreadTerminateTimeout" value="5000" />
</Options>
Directory of my options.xml is /srv/hass/hass_venv/lib/python3.4/site-packages/libopenzwave-0.3.1-py3.4-linux-armv7l.egg/config if that helps.
If you can find anything, I really appreciate it!
Sorry, I know next to nothing about network keys; in fact I wasn’t even sure what they were when they showed up in my states panel as I never set them up. Hopefully someone else will check in on this.
Hmm, would this help at all?
That’s actually the page I linked in the OP lol. The only thing I think is different on my end is directories. Should I start a new thread, since my original problem is gone?
Sorry; I forgot that link was there…
Have you by chance looked at this other similar thread here? Looks like he fixed his issue using another HA platform called Domoticz, ever used it?
No, I’ve seen the thread and seen mentions of Domoticz other places but never used it.
I’m having the exact same problem as well. Raspberry Pi3, Aeotec Z-Stick Gen5, and a Schlage Connect (BE469). Just set up a clean install of the RPI All-In-One Installer, and am on HA 26.2. I’ve been trying to add the lock through ozwcp since that seems like the most foolproof method.
  1. Start ozwcp
  2. Initialize the controller at /dev/ttyACM0.
  3. Controller -> Add Device
  4. Go to Schlage Connect and try to enroll device.
OZWCP Log File:
2016-08-15 05:57:59.414 Detail, Queuing (Controller) Add Device 2016-08-15 05:57:59.414 Info, Add Device 2016-08-15 05:57:59.414 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b 2016-08-15 05:57:59.415 Detail, Notification: ControllerComand - Starting 2016-08-15 05:57:59.415 Info, Notification: ControllerCommand home f216247e Event 1 Error 0 2016-08-15 05:57:59.415 Detail, 2016-08-15 05:57:59.415 Info, contrlr, Sending (Command) message (Callback ID=0x0a, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b 2016-08-15 05:57:59.418 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x07, 0x00, 0x00, 0xbf 2016-08-15 05:57:59.418 Detail, 2016-08-15 05:57:59.418 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK: 2016-08-15 05:57:59.418 Info, contrlr, ADD_NODE_STATUS_FAILED 2016-08-15 05:57:59.419 Detail, contrlr, Removing current message 2016-08-15 05:57:59.419 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4 2016-08-15 05:57:59.419 Detail, Notification: ControllerCommand - Failed 2016-08-15 05:57:59.419 Info, Notification: ControllerCommand home f216247e Event 8 Error 0 2016-08-15 05:57:59.419 Detail, 2016-08-15 05:57:59.419 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4 2016-08-15 05:57:59.472 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x06, 0x00, 0x00, 0xbe 2016-08-15 05:57:59.472 Detail, 2016-08-15 05:57:59.472 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK: 2016-08-15 05:57:59.472 Detail, Node006, Expected reply was received 2016-08-15 05:57:59.473 Detail, Node006, Message transaction complete 2016-08-15 05:57:59.473 Detail, 2016-08-15 05:57:59.473 Detail, contrlr, Removing current message 2016-08-15 05:57:59.473 Detail, Notification: ControllerCommand - Completed 2016-08-15 05:57:59.473 Info, Notification: ControllerCommand home f216247e Event 7 Error 0
When I try to enroll the Schlage connect lock, it looks like OZWCP doesn’t even log any additional lines (not communicating with the lock).
When i naively tried to pair the lock in HA before adding a network key in ozwcp, I noticed that although enrollment would fail on the Connect lock (I’ve never gotten a green checkbox on my lock to flash), it looked like HA would notice the lock as I could see it in HA though none of the settings in HA would work.
RPhilipps16, are you seeing the same thing?
Been searching through OpenZWave threads, it seems that mucking around with the zwcfg file may help. Haven’t tried it yet.
https://groups.google.com/forum/#!searchin/openzwave/network$20key|sort:date/openzwave/Jqs-UZeOhiA/dYWRjmzAAwAJ
Probably a dumb question, but did you try “Add device (secure)” instead of “add device” in ozwcp?
I think I’m just gonna try factory resetting everything and hope I messed something stupid up when installing
Yeah I’ve been trying both, with no success either way. When you set up your Pi3, did you use the All-In-One installer (https://home-assistant.io/getting-started/installation-raspberry-pi-all-in-one/) or did you install openzwave separately?
And when you were able to initially pair the stick with the lock, was that through ozwcp? I haven’t been able to see any communication between the stick and the lock in logs, and I’ve already ruled out any malfunction with my stick or RPi as it pairs other z-wave non-secure devices fine, which is incredibly frustrating.
I think I may have done both by accident. Not sure if that would result in two different Z wave directories. What’s frustrating is that I haven’t had any devices pair, secure or not. I also have a First Alert smoke/CO detector and an Aeotec Minimote (just got today so I haven’t tried too hard), both with no luck so far. Hopefully the reinstall will fix that
Again, I’ve tried both through just the stick (press it to enter pairing) and through ozwcp. Does the stick need to stay connected to the Pi to get ozwcp pairing to work?
I’ve always paired it through Home Assistant or paired it in testing through ozwcp.
In HA, go to http://localhost:8123/dev-service and on the right side you should see a bunch of services you can call. Among them, if you’ve set up openzwave properly, add_node and add_node_secure. This has helped me when trying to debug since then there are log files :slight_smile:
Does the stick need to be connected to the pi during that method, or do you take it out and enter pairing through the stick?
