Its probably just the default NGINX default conf file. A lot in what you posted looks different then mine. You can try mine if it helps. Just replace your “mydomain.duckdns.org” with your actual duckdns domain and the IP address under Home Assistant with your actual machine’s IP address. Leave all the other IP references alone as those are loopbacks within the Swag container itself (for fast CGI and resolver)
## Version 2020/05/23 - Changelog: https://github.com/linuxserver/docker-swag/commits/master/root/defaults/default
# redirect all traffic to https
server {
listen 80 default_server;
listen [::]:80 default_server;
server_name mydomain.duckdns.org;
return 301 https://$host$request_uri;
# main server block
server {
listen 443 ssl http2 default_server;
listen [::]:443 ssl http2 default_server;
root /config/www;
index index.html index.htm index.php;
# enable subfolder method reverse proxy confs
include /config/nginx/proxy-confs/*.subfolder.conf;
# all ssl related config moved to ssl.conf
include /config/nginx/ssl.conf;
# enable for ldap auth
#include /config/nginx/ldap.conf;
# enable for Authelia
#include /config/nginx/authelia-server.conf;
# enable for geo blocking
# See /config/nginx/geoip2.conf for more information.
#if ($allowed_country = no) {
#return 444;
client_max_body_size 0;
location / {
try_files $uri $uri/ /index.html /index.php?$args =404;
location ~ \.php$ {
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
include /etc/nginx/fastcgi_params;
### HOMEASSISTANT ##############################################################
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name hass.*;
# enable for ldap auth, fill in ldap details in ldap.conf
location / {
# enable the next two lines for http auth
#auth_basic "Restricted";
#auth_basic_user_file /config/nginx/.htpasswd;
# enable the next two lines for ldap auth
#auth_request /auth;
#error_page 401 =200 /login;
include /config/nginx/proxy.conf;
resolver 127.0.0.11 valid=30s;
set $upstream_app homeassistant;
set $upstream_port 8123;
set $upstream_proto http;
proxy_pass http://192.168.0.184:8123;
location /api/websocket {
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
# enable subdomain method reverse proxy confs
include /config/nginx/proxy-confs/*.subdomain.conf;
# enable proxy cache for auth
proxy_cache_path cache/ keys_zone=auth_cache:10m;
