Nginx Reverse Proxy Set Up Guide – Docker
Yes it is working fine for me still with 2021.7. Take a look at my posts above with my docker compose, NGINX config, and home assistant config to see if you have any differences you need to change. The only thing that I had to add were the same lines you just posted to the home assistant config for http: settings to keep this working. It’s possible there was something else missing in your docker compose or NGINX config though that didn’t matter before but is creating a problem for you now.
