Based on your configuration i would try,
sensor.bruins_home_team and sensor.bruins_away_team
You have the heading sensor defined twice under the template section of your configuration. Remove the second one. And your template sensors are named sensor.home_team and sensor.away_team.
I updated configuration.yanl to:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
#NHL API Sensor for Bruins... GO BRUINS!
- platform: nhl_api
team_abbrev: BOS
scan_interval: 6
template:
- unique_id: away_team
name: '{{ states.sensor.bruins.attributes.get("away_name", "") }}'
state: '{{ states.sensor.bruins.attributes.get("away_score", "") }}'
picture: '{{ states.sensor.bruins.attributes.get("away_logo", "") }}'
- unique_id: home_team
name: '{{ states.sensor.bruins.attributes.get("home_name", "") }}'
state: '{{ states.sensor.bruins.attributes.get("home_score", "") }}'
picture: '{{ states.sensor.bruins.attributes.get("home_logo", "") }}'
And still get the same error âEntity not availableâŚâ
I also tried with
sensor.home_team and sensor.bruins_away_team and sensor.bruins_home_team and sensor.away_team.
So after some trial and error, I discovered there were several errors in the error log, I continued to correct the code (following other examples) and finally got this configuration which didnât cause any errors⌠but still it shows the entities are not available on the cards:
#ControlByWeb Generator Monitors
#shop 468
- platform: snmp
accept_errors: true
unique_id: 2024468
host: !secret shop468_IP
port: !secret x410_port
community: !secret x410_community
baseoid: 1.3.6.1.4.1.30586.46.0.10.0
unit_of_measurement: "Hours"
version: 2c
- platform: nhl_api
team_abbrev: BOS
scan_interval: 6
template:
- sensor:
- sensor:
the configuration should be:
template:
- sensor:
You only need to have one sensor heading under the template heading. I bet thereâs an error in your log for invalid configuration for template with the sensor heading twice.
I changed the configuration to remove the second sensor⌠but its still not working. I feel like I have it character for character as per the examples and everyoneâs recommendations, but its not working.
Here is what I changed it to:
template:
- sensor:
Here is the whole configuration file for referenceâŚ
default_config:
frontend:
#shop 468
- platform: snmp
accept_errors: true
unique_id: 2024468
version: 2c
- platform: nhl_api
team_abbrev: BOS
scan_interval: 6
template:
- sensor:
Here is the home-assistant-log:
2024-01-09 21:18:23.935 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-01-09 21:18:23.937 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration nhl_api which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-01-09 21:18:23.939 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-01-09 21:18:23.941 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration teamtracker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-01-09 21:18:44.203 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'custom_components.hacs.update.HacsRepositoryUpdateEntity'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <UpdateEntityFeature.INSTALL|PROGRESS|RELEASE_NOTES: 21>, please create a bug report at https://github.com/hacs/integration/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-01-09 21:18:44.206 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'custom_components.hacs.update.HacsRepositoryUpdateEntity'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <UpdateEntityFeature.INSTALL|PROGRESS|RELEASE_NOTES: 21>, please create a bug report at https://github.com/hacs/integration/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-01-09 21:18:44.207 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'custom_components.hacs.update.HacsRepositoryUpdateEntity'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <UpdateEntityFeature.INSTALL|PROGRESS|RELEASE_NOTES: 21>, please create a bug report at https://github.com/hacs/integration/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-01-09 21:18:44.212 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'custom_components.hacs.update.HacsRepositoryUpdateEntity'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <UpdateEntityFeature.INSTALL|PROGRESS|RELEASE_NOTES: 21>, please create a bug report at https://github.com/hacs/integration/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
And home-assistant-log-1:
2024-01-09 04:33:56.503 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-01-09 04:33:56.507 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration nhl_api which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-01-09 04:33:56.510 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-01-09 04:33:56.515 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration teamtracker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-01-09 04:34:02.280 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-01-09 04:34:02.482 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=18 from 2024-01-09 07:39:57.242405)
2024-01-09 04:34:27.960 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'custom_components.hacs.update.HacsRepositoryUpdateEntity'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <UpdateEntityFeature.INSTALL|PROGRESS|RELEASE_NOTES: 21>, please create a bug report at https://github.com/hacs/integration/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-01-09 04:34:27.962 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'custom_components.hacs.update.HacsRepositoryUpdateEntity'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <UpdateEntityFeature.INSTALL|PROGRESS|RELEASE_NOTES: 21>, please create a bug report at https://github.com/hacs/integration/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-01-09 04:34:27.965 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'custom_components.hacs.update.HacsRepositoryUpdateEntity'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <UpdateEntityFeature.INSTALL|PROGRESS|RELEASE_NOTES: 21>, please create a bug report at https://github.com/hacs/integration/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-01-09 04:34:27.967 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'custom_components.hacs.update.HacsRepositoryUpdateEntity'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <UpdateEntityFeature.INSTALL|PROGRESS|RELEASE_NOTES: 21>, please create a bug report at https://github.com/hacs/integration/issues and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-01-09 04:45:53.704 ERROR (MainThread) [homeassistant.components.roku.coordinator] Error fetching roku data: Invalid response from API: Timeout occurred while connecting to device
2024-01-09 11:13:26.111 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [546970150080] from 127.0.0.1 (Mozilla/5.0 (Linux; Android 14; Pixel 6 Build/UQ1A.231205.015; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/120.0.6099.144 Mobile Safari/537.36 Home Assistant/2023.12.4-11898 (Android 14; Pixel 6)): Disconnected: Did not receive auth message within 10 seconds
2024-01-09 11:38:15.345 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [546970312896] from 127.0.0.1 (Mozilla/5.0 (Linux; Android 14; Pixel 6 Build/UQ1A.231205.015; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/120.0.6099.144 Mobile Safari/537.36 Home Assistant/2023.12.4-11898 (Android 14; Pixel 6)): Disconnected: Did not receive auth message within 10 seconds
2024-01-09 14:46:34.444 ERROR (MainThread) [smart_meter_texas] Unknown meter reading status: FAILED
2024-01-09 14:46:34.445 ERROR (MainThread) [homeassistant.components.smart_meter_texas] Error fetching Smart Meter Texas data: Unknown meter status: FAILED
2024-01-09 19:52:08.935 ERROR (MainThread) [homeassistant.components.smart_meter_texas] Error requesting Smart Meter Texas data: 0, message='Attempt to decode JSON with unexpected mimetype: text/html', url=URL('https://smartmetertexas.com/api/ondemandread')
Ok I see whatâs possibly going on. First, you have an indentation problem in the template/sensor section. move the 8 lines under the - sensor heading 2 spaces to the left. then, search your list of entities from the frontend for a sensor that says âsensor.vegas_golden_knightsâ. Second, whatâs happening is as of right now (1/11) Boston is playing Vegas. The home_name attribute of your sensor.bruins sensor is populated with âVegas Golden Knightsâ. This value is entered into the name: field for you template sensor. That means the name of the sensor is sensor.vegas_golden_knights and the name will change every game. the same is true for the away team sensor which should be sensor.boston_bruins right now and will change accordingly for their next game. The only way I have been able to get around this is doing the old template sensor format (you are currently using the new template format). See my config example below for the old template format. Notice how instead of the template: section, Iâm creating a sensor of the platform template:
- platform: nhl_api
team_abbrev: NSH
sensors:
away_team:
friendly_name_template: '{{ state_attr("sensor.nashville", "away_name") }}'
value_template: '{{ state_attr("sensor.nashville", "away_score") }}'
entity_picture_template: '{{ state_attr("sensor.nashville", "away_logo") }}'
home_team:
friendly_name_template: '{{ state_attr("sensor.nashville", "home_name") }}'
value_template: '{{ state_attr("sensor.nashville", "home_score") }}'
entity_picture_template: '{{ state_attr("sensor.nashville", "home_logo") }}'
now, my sensor names will always be sensor.away_team and sensor.home_team. The friendly name is what changes every game but the actual sensor id stays the same. Additionally, using state_attr("...") allows the sensor to properly handle the unavailable state in the event the template renders whenever the sensor.nashville doesnât exist like on HA startup and not everything is loaded, or in the off season, or if the integration cannot fetch data.
Thank you so much for the help with this, that got it working⌠at least I got one victory tonight⌠too bad the Bruins didnâtâŚ
Currently Iâve got an issue with the API showing the incorrect data for tonights game. Itâs stuck showing the Oilers as OFF after Colorado last night. Tried restarting etc. no change.
Happening on two seperate HA installs on very different machines.
Found some logs:
Update for sensor.oilers fails
File "/usr/local/lib/python3.12/site-packages/homeassistant/helpers/entity.py", line 951, in async_update_ha_state
await self.async_device_update()
File "/usr/local/lib/python3.12/site-packages/homeassistant/helpers/entity.py", line 1270, in async_device_update
await hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/nhl_api/sensor.py", line 204, in update
self.set_state()
File "/config/custom_components/nhl_api/sensor.py", line 164, in set_state
all_attr = self.get_game_data()[0]
File "/config/custom_components/nhl_api/sensor.py", line 108, in get_game_data
if Plays(game_id).scoring_info() is not None:
File "/config/.local/lib/python3.12/site-packages/pynhl/classes.py", line 298, in scoring_info
event_type = plays[i]["typeDescKey"]
IndexError: list index out of range
I saw you submitted this issue on Github as well. I will see if I can get to the bottom of it. Usually this happens when the NHL tweaks their API endpoints.
Is there any way to create a helper template as binary sensor for when a goal is scored? I tried the below but the state doesnât change.
platform: event
event_type: nhl_goal
event_data:
goal_tracked_team: true
It just changes the state to off but nothing in the logbook for it turning on. I havenât tested it live yet, but should it work? I can test again for tomorrowâs game.
Great work by the way, the reaction is instant. Much better than team tracker.
You can create an automation using the event as a trigger to turn the binary sensor on, add a delay and then turn it off.
What are you trying to accomplish with the binary sensor though?
Please forgive this newbie question but can someone provide an example of how to add ânext_game_datetimeâ to configuration.yaml for the NHL API? I have the following in my current config as a placeholder:
- platform: nhl_api
team_abbrev: BOS
scan_interval: 60
template: - sensor:
{{state_attr(âsensor.bruinsâ,âaway_nameâ)}}
state: >
{{state_attr(âsensor.bruinsâ, âaway_scoreâ)}}
picture: >
{{state_attr(âsensor.bruinsâ,âaway_logoâ) }}
- sensor:
{{state_attr(âsensor.bruinsâ,âhome_nameâ)}}
state: >
{{state_attr(âsensor.bruinsâ, âhome_scoreâ)}}
picture: >
{{state_attr(âsensor.bruinsâ,âhome_logoâ) }}
next_game_datetime should already be exposed as an attribute of your sensor.bruins sensor. Make sure you restart Home Assistant after adding the sensor to your config.
Thank you. I hadnât created a sensor for next_game_datetime, which I think was my problem. My config looks as follows. I hope Iâm doing this correctly.
- platform: nhl_api
team_abbrev: BOS
scan_interval: 60
template:
- sensor:
state: >
picture: >
- sensor:
state: >
picture: >
- sensor:
- unique_id: next_game
state: >
{{state_attr(âsensor.bruinsâ,ânext_game_datetimeâ)}}
Yes, that should work if youâre looking to create a distinct sensor that will display the next gameâs date and time as a state.
Jay,
I was looking for a way to display the next game date/time for an area I named âHockeyâ but I donât know where to read up on how to do this.
Thank you for your feedback.
Hello Jay,
First fantastic work to bring those nhl updates. Iâm very new with Home-Assistant so Iâm discovering and I have a question for you regarding updates of the API after a reboot.
So during a game, I had to restart Home Assistant (was doing some tweaks and modifications live to test) and I realized that the card updates the score right after the reboot (at the initialization I presume) and doesnât update anymore until the next game.
Have you ever encounter this? Or did I misconfigure something?
Thanks for your help,
Cheers!
This has to do with how the sensor is programmed to update. Fixing it would require a full rewrite which isnât really in the cards for me right now. I am accepting PRs if someone would like to give it a go.
Once set up, the sensor will have an attribute called next_game_datetime that you can use.
