Somehow, with my Nibe F730 (F375G) and this Nibe / HA integration, I don’t get the defrosting sensor (43066) at all, as far as I can see.
I am coming from openHAB where I used their Nibe addon. There I was able to get the defrosting data, but with this HA integration its just not there. What can I do to get that data?
“Thanks elupus for setting this up, it looks great. I can now see lots of measurements in my home assistant that will now require me to take a PhD in Nibe to understand!”
Same for me.
Hi, Nibe measures the consumed total power in KWH. You can differentiate that power to time to get the actual consumed power. But that didn’t work so well.
I have installed an 3 phase Iammeter on the powercords that measures the actual elektrical power consumed by the heatpump in KW’s. And I have the Iammeter integrated in Home Assistant. https://nl.iammeter.com/products/three-phase-meter
To calculate the produced energy by the heatpump you need the flow and the temperature difference of the in- and outcoming flow. Therefore I installed a flowmeter.
This works well. If you need more detailed ino, let me know.
Regards, Tim.
I tried to setup the component before API process was completed. Of course it failed. However, now I am stuck not being able to try to set it up again. When I try to it I get the following message:
Sorry, there was an error : invalid_request
Request Id: 0HMS23LVQNF9I:00000001
I guess something needs to be reset so that I can enter the information again att get a new possibility to setup the integration, I just do not know what to do. Can anyone guide me?
Hi, I have the following behaviour:
The connection status of my system is all the time switching from online to pending.
About 8 minutes pending and then it switches to 1 minute online and reverse and so on.
Why is that? Can I change that?
Tim.
That’s how the uplink works, it polls with a intervall, it’s not a constant connection the the heat pump.
That’s what the colored dot in the uplink page displays.
Is the solution to block/unblock compressor for f-pumps thus to have to have a esp connected to those ports on the pump? It can’t be done programmatically?
Thank you all for the effort with the Nibe Uplink integration.
I currently have a connection to the cloud for my F750 which reads all the stats. However trying to change the few parameters that’s actually are steerable I always get an error.
As an example trying to change the option of boosting the hotwater gives an error that the option is not supported in the api. Trying to control the fan gives “unknown error” etc.
Yes I have a paid subscription and the remote options works from the NIBE portal.
Am I doing anything wrong or is it a limitation of the API?
