Nicehash Component
You need to restart your home assistant instance, it will show up.
Hey all, is there any way to get HWinfo64 sensors into HA?
I must be an idiot as well, but I have been unable to find where the Org ID is.
I did manage to get half of it working, but can you tell me which theme you’re using?
Hardware monitor is something i’ll install later today so thats why its offline.
Hey, I use an IOS theme: https://github.com/basnijholt/lovelace-ios-dark-mode-theme
& a custom background on my Lovelace page
:blush:
Is there an issue with the it not showing in the integrations list after adding the hacs component? ive redownloaded it and restarted homeassistant several times.
shows in mine:
I’m having the same issue, and I have restarted. My logs show WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration nicehash which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant however the integrations list in Configuration > Info doesn’t list it, and it isn’t listed to be added in Configuration > Integrations > Add Integration. Any ideas?
Never mind. Started working. Don’t know why.
Just wanted to say a big thank you to RomRider! This integration is amazing! I am one step closer to automating the shutdown of my 3080ti if VRAM temps get to high due to hot days here in South Africa. Just need to figure out how to get that VRAM temp into home assistant but I’ll figure that out. RomRider my friend, you are a legend! Thank you
Is anyone still using this? I just implemented HA and found this integration.
However, it never updates the values after the first restart of the integration.
I have used it for quite many months without any issues, just needed to add the automation to restart the integration at fixed intervalls to update values. But today values from Nice Hash became unavalailable for both me and my brother in his HA, did you experience the same?
надаю код для автоматичного оновлення показників (перевантажую інтеграцію кожні 10хв) - для перекладу використовуйте українську мову :slight_smile:
reload_nicehash_integration:
automation:
- id: reload_nicehash_integration
alias: Перезавантаження інтеграції NiceHash кожні 10 хвилин
description: Перезавантажує інтеграцію NiceHash для оновлення даних
- platform: time_pattern
minutes: “/10”
condition:
- service: homeassistant.reload_config_entry
entry_id: 01JXWWVFZG2BWG07QQFCFF7R0K # Замініть на ваш config_entry_id
mode: single
And suddenly:
Logger: homeassistant.config_entries
Source: config_entries.py:749
First occurred: June 17, 2025 at 1:25:31 PM (47 occurrences)
Last logged: 10:32:59 AM
Error setting up entry Hassio API for nicehash
Error setting up entry HASSIO for nicehash
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 749, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File “/config/custom_components/nicehash/init.py”, line 92, in async_setup_entry
hass.config_entries.async_forward_entry_setup(entry, platform)
AttributeError: ‘ConfigEntries’ object has no attribute ‘async_forward_entry_setup’. Did you mean: ‘async_forward_entry_setups’?
Not working anymore?!
