Nissan Leaf Component(s)/Platform
@andbad Running 0.117.6 fine here, sorry :confused:
You’re right. From yesterday, the error has returned. :frowning:
Today, I upgraded again to 0.117.6 and the error go away. It’s very strange.
Is there any kind of cache in the code?
EDIT: Nothing to do. After some restarts of HA, it has returned again. I don’t know what to do.
By(t)e
That seems to be the way it is, it’s usually the Nissan servers that are at fault (but not always)
It’s not Nissan servers.
  • All works ok.
  • Restart HA
  • Got the error.
  • Downgrade to 0.117.5
  • Upgrade to 0.117.6
  • Restart HA
  • All works ok
I make this steps in about 5 minutes. Meanwhile, the Nissan app and website works normally.
So, I think that something break when I restart HA.
By(t)e
It’s hit and miss depending on when you restart HASS and whether the Nissan servers are responding at that very moment, hence the inconsistency. Even when they seem relatively stable they can still do a bad reply
I doubt they changed anything, as they’re trying to phase this API out
I think that somethig break inside HA, when I restart it.
The API and the integration seems to work fine.
I wonder if upgrade did break the component? I get the same CarwingsError. After 0.118.0 upgrade all leaf enties gone. Usally when there is server problem the entites do not go away.
It is working on hassio 0.116.4
I confirm that the entities gone.
Post your details here: https://github.com/home-assistant/core/issues/43194
By(t)e
The integration broke between 0.118.0b2 and 0.118.0b3.
See this issue: https://github.com/home-assistant/core/issues/43312
Yeah, 0.118.0 has broken it a little. :slight_smile:
Has anyone updated to 0.118.2? Has it been repaired in that version?
Yes I’m running on 0.118.2 and problem remains.
Thanks, in that case I wouldnt update until fixed.
Has anyone updated to 0.118.4? Is it working now?
Nope. Its still missing
Same problem here. 0.118.4 still has the problem.
And 0.118.5 still has the issue as well. The integration is dead.
Going off the findings in that issue, it seems an update to the requests library broke it as there’s now a default user agent, which the Nissan API doesn’t like.
Does anyone know how to work around this?
Only fix atm is to downgrade to version 0.117.6
