Nissan Leaf Component(s)/Platform
Thanks for this. I’ve installed the Terminal add-on and successfully connected from my PC using Putty and logged in as root, with the settings for unprotected access. However, I am getting an error message:
-bash: docker: command not found
I went back to the forum that is linked to and I see that the command is intended to modify a file. However in my installation of Home Assistant the file isn’t in the directory that is referenced in the command. I’ve been exploring directories through the terminal and cannot find where the pycarwings2.py file is stored and I just cannot find a post describing the directory structure!
Any idea where I would find the pycarwings file within my Home Assistant directory structure, please!
It depends on the type of installation of your Home Assistant instance.
In my case, I installed HA via VENV, so the file to edit is in:
~/homeassistant/lib64/python3.12/site-packages/pycarwings2/pycarwings2.py
By(t)e
Nissanconnect don’t update value from 2 weeks. Isn’t a component issue, because also the app and website don’t update the SOC value.
Do you find any problem in last days?
By(t)e
