@rbray89 let the install run overnight and just checked the log and found a bunch of the same errors:
2018-09-01 22:57:47 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
TimeoutError: [Errno 110] Operation timed out
2018-09-01 22:58:09 ERROR (MainThread) [homeassistant.components.updater] Got unexpected response: None
2018-09-01 22:58:40 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
2018-09-01 23:09:01 WARNING (Thread-5) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-09-01 23:09:16 ERROR (Thread-5) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-09-01 23:35:28 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof
File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:841)
2018-09-01 23:35:28 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: UNKNOWN_PROTOCOL
File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received
File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
2018-09-01 23:46:07 ERROR (InfluxDB) [homeassistant.components.influxdb] Write error
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/influxdb.py", line 316, in write_to_influxdb
self.influx.write_points(json)
File "/usr/local/lib/python3.6/site-packages/influxdb/client.py", line 468, in write_points
tags=tags, protocol=protocol)
File "/usr/local/lib/python3.6/site-packages/influxdb/client.py", line 532, in _write_points
protocol=protocol
File "/usr/local/lib/python3.6/site-packages/influxdb/client.py", line 312, in write
headers=headers
File "/usr/local/lib/python3.6/site-packages/influxdb/client.py", line 271, in request
raise InfluxDBClientError(response.content, response.status_code)
influxdb.exceptions.InfluxDBClientError: 400: {"error":"partial write: unable to parse '°C,domain=sensor,entity_id=bijkeuken_gevoelstemperatuur friendly_name_str=\"Bijkeuken gevoelstemperatuur\",value=nan 1535838306050802944': invalid number dropped=0"}
2018-09-01 23:46:08 ERROR (InfluxDB) [homeassistant.components.influxdb] Resumed, lost 4 events
2018-09-02 00:00:00 ERROR (MainThread) [homeassistant.core] Invalid service data for hassio.addon_restart: invalid slug core_letsencrypt[] (try core_letsencrypt) for dictionary value @ data['addon']. Got 'core_letsencrypt[]'
2018-09-02 00:20:05 WARNING (MainThread) [buienradar.buienradar] Missing section in Buienradar xmldata (weerstation).Can happen 00:00-01:00 CE(S)T
2018-09-02 00:22:08 WARNING (MainThread) [buienradar.buienradar] Missing section in Buienradar xmldata (weerstation).Can happen 00:00-01:00 CE(S)T
2018-09-02 01:44:48 WARNING (MainThread) [homeassistant.components.sensor.buienradar] Unable to retrieve raindata from Buienradar.(Msg: , status: None,)
2018-09-02 03:26:23 WARNING (Thread-5) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-09-02 03:26:30 ERROR (Thread-5) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-09-02 03:29:35 WARNING (Thread-4) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-09-02 03:29:50 ERROR (Thread-4) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-09-02 04:07:59 WARNING (Thread-3) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-09-02 04:08:14 ERROR (Thread-3) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-09-02 05:33:21 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
ssl.SSLError: [SSL: NO_SHARED_CIPHER] no shared cipher (_ssl.c:841)
2018-09-02 05:33:21 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: NO_SHARED_CIPHER
2018-09-02 07:39:00 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:841)
2018-09-02 07:39:00 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: WRONG_VERSION_NUMBER
2018-09-02 09:08:31 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:841)
2018-09-02 09:08:31 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
I have setup the example automation as provided with the docs for the letsencrypt addon, to check for renewal at midnight, but looking at the timestamps, these errors did not happen as a consequence…
Is this anything you can get useful info from?
