No clue where to begin with MQTT
Here ya go! Thank you!!
Also, this is what the below code is displaying on my clock:
The hours and minutes are displaying on their correct digits, but the blinking dots are in the bottom right corner of the rightmost digit.
substitutions:
  device_name: poolclock
esphome:
  platform: ESP8266
  board: d1_mini
  on_boot:
    - light.turn_on:
        brightness: 100%
        red: 0
        green: 0
        blue: 0
        effect: ${device_name} Time effect
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "${device_name} Fallback Hotspot"
    password: !secret wifi_fallback_api_password
logger:
  level: DEBUG
api:
  #password: !secret hassio_api_password
  encryption:
    key: !secret hassio_api_key
ota:
  password: !secret ota_password
globals:
  - id: hours_red_value
    type: int
    restore_value: yes
    initial_value: "0"
  - id: hours_green_value
    type: int
    restore_value: yes
    initial_value: "0"
  - id: hours_blue_value
    type: int
    restore_value: yes
    initial_value: "0"
  - id: minutes_red_value
    type: int
    restore_value: yes
    initial_value: "0"
  - id: minutes_green_value
    type: int
    restore_value: yes
    initial_value: "0"
  - id: minutes_blue_value
    type: int
    restore_value: yes
    initial_value: "0"
  - id: dots_red_value
    type: int
    restore_value: yes
    initial_value: "0"
  - id: dots_green_value
    type: int
    restore_value: yes
    initial_value: "0"
  - id: dots_blue_value
    type: int
    restore_value: yes
    initial_value: "0"
output:
    type: float
    write_action:
      lambda: id(hours_red_value) = 255.0 * state;
    type: float
    write_action:
      lambda: id(hours_green_value) = 255.0 * state;
    type: float
    write_action:
      lambda: id(hours_blue_value) = 255.0 * state;
    type: float
    write_action:
      lambda: id(minutes_red_value) = 255.0 * state;
    type: float
    write_action:
      lambda: id(minutes_green_value) = 255.0 * state;
    type: float
    write_action:
      lambda: id(minutes_blue_value) = 255.0 * state;
    type: float
    write_action:
      lambda: id(dots_red_value) = 255.0 * state;
    type: float
    write_action:
      lambda: id(dots_green_value) = 255.0 * state;
    type: float
    write_action:
      lambda: id(dots_blue_value) = 255.0 * state;
time:
  - platform: sntp
    timezone: America/Los_Angeles
    servers:
      - 0.pool.ntp.org
      - 1.pool.ntp.org
      - 2.pool.ntp.org
light:
  - platform: rgb
    name: ${device_name} hours lights
    red: hours_red_output
    green: hours_green_output
    blue: hours_blue_output
  - platform: rgb
    name: ${device_name} minutes lights
    red: minutes_red_output
    green: minutes_green_output
    blue: minutes_blue_output
  - platform: rgb
    name: ${device_name} dots lights
    red: dots_red_output
    green: dots_green_output
    blue: dots_blue_output
  - platform: neopixelbus
    internal: true
    pin: GPIO2
    num_leds: 86
    variant: WS2812
    type: GRB
    effects:
      - addressable_lambda:
          name: ${device_name} Time effect
          update_interval: 200ms
          lambda: >-
            const int ledsInDigitCount = 21;
            const int digitsCount = 4;
            int digitsLeds[11][ledsInDigitCount] = {
              {0,1,1,1,1,1,1},
              {0,0,0,1,1,0,0},
              {1,0,1,1,0,1,1},
              {1,0,1,1,1,1,0},
              {1,1,0,1,1,0,0},
              {1,1,1,0,1,1,0},
              {1,1,1,0,1,1,1},
              {0,0,1,1,1,0,0},
              {1,1,1,1,1,1,1},
              {1,1,1,1,1,1,0},
              {0,0,0,0,0,0,0}
            int ledOffsets[digitsCount] = {65 , 44 , 21, 0};
            auto time = id(sntp_time).now();
            int colors[4][3] = {
             {id(hours_red_value), id(hours_green_value), id(hours_blue_value)},
             {id(minutes_red_value), id(minutes_green_value), id(minutes_blue_value)},
            int values[digitsCount] = {};
            values[0] = time.hour / 10;
            values[1] = time.hour % 10;
            values[2] = time.minute / 10;
            values[3] = time.minute % 10;
            it.all() = Color(0,0,0);
            if ((time.second % 2) > 0) {
             it[14] = Color(id(dots_red_value), id(dots_green_value), id(dots_blue_value));
             it[15] = Color(id(dots_red_value), id(dots_green_value), id(dots_blue_value));
            for (int valueI = 0; valueI < digitsCount; valueI++) {
              int ledsOffset = ledOffsets[valueI];
              int timeValue = values[valueI];
              int *color = colors[valueI];
              int *leds = digitsLeds[timeValue];
            for (int ledI = 0; ledI < ledsInDigitCount; ledI++) {
             if(leds[ledI] > 0) {
             int ledIndex = ledI + ledsOffset;
             it[ledIndex] = Color(color[0], color[1], color[2]);
What should we see?
It should be showing numbers and the dots should be lit up. It’s only lighting up part of the display.
Perhaps dividing up into partitions Light Partition — ESPHome
Yeah, that is what I was thinking, but I’m not sure where in my code that should go, and how to reference the partitions so that it displays correctly. Do you have any experience with this?
Thanks!!
Not much. I did some simple partitioning for some stair lights. And I can’t follow the logic in your code (my fault, not yours).
