No entities for Devolo Z-Wave switches switch
I got it working, I used the PR from here: “Central Scene” Command Class - Fibaro Swipe, HomeSeer WS-100D Switches
It then enabled Node Config Options and I was able to use Default Central Scene to Gateway. After this is set, you can force the switch to wakeup (Maagement Mode -> Button 2) and the setting will be applied. Don’t forget to update zwcf* config file, otherwise events will not be triggered. Used this for automation: https://www.home-assistant.io/docs/z-wave/events/
