Does something special have to be done in Hass.io to enable running python scripts from a command_line sensor or switch? If I create a command_line switch that is supposed to execute the following command:
python3 /path/to/my/script.py
I get a “Command failed” error in the logs. If SSH to Hass.io and try to execute the same command, I get:
“-ash: python3: not found”
I’ve seen other threads that seem to imply that people are successfully doing what I’m trying to do here under Hass.io, but I can’t figure out what I’m missing. Any suggestions?
I am trying to run a command_line sensor as a python script. Normally I am using bash, which is not a problem, but when I ssh to hassio, I have no “python” command.
