The NOCTIS theme is indeed a relaxed and modest theme. However I would like to be able to kinda ‘group’ my buttons visibly. They are currently in a vertical-stack, but I cannot find the way to set the background of the vertical stack to anything else but transparent, as what it is now.
I have been scratching my head, but cannot find it. It must be something obvious.
Found it myself. It is even simpler than I expected.
Instead of using a vertical-stack, use the built-in ‘Entities’ card and identify the cards as being entities.
This was the original:
type: vertical-stack
cards:
Which I turned into this:
type: entities
entities:
The custom cards within the - initially - vertical stack are perceived as entities. For the built-in cards, you need to change it into:
I noticed and thanks @thomasloven for pointing it out. The hui-horizontal-stack and hui-vertical-stack work flawlessly, the ones starting with a ‘g’ are less reliable
hui-gauge-card and hui-grid-card have persistent issues. I’ll switch over to either other custom cards in combination with your proposed hui-element.
I’ve also tried adding the ref to /local/popup-background.js through the Lovelace config in the UI, it seems to be loaded by the network calls in the browser developer tools.
It doesn’t work this way anymore. I need to update my readme
You can do this with Card-mod - Super-charge your themes!. I have published a new release with the code I’m using. If you have card-mod installed you can uncomment the lines in the bottom to get the blur effect.
Could someone upload a noctis.yaml that has card-mod-theme uncommented?
I can not for the love of me get that simple un-commenting to work.
I get errors in configuration check all the time.
love your clean theme. But the behaviour on entity-state-on is not what I expected.
After installation, my switch- and light-cards change icon-colour to blue in on-state. The background stays dark, even on on-state.
According to your screenshots I expected for my switch- and light-cards state-on-dependent…
blue background-color and
white icon-color
Have I done something wrong during installation of the theme? Where is the right place do define this behaviour? Can it be defined once (in the themes.yaml or somewhere else) or has it to be defined for each button seperately? And how has it to be definied? Which variable is the right one to set a blue background?
