Are you using ssl in your home assistant? If not, turn it to false.
This fixed my issue! Thank you!
Thank you so much, this helped me too!
with the 13.3.0 version, i make SSL false and it’s OK
I solved it by adding a value to the credential_secret
can i ask where this value is to be added, config i guess somewhere
My nodered has been giving me endless problems since going to version 13. it crashes at night and i have to start it every morning, i have 30 mayor flows and i now find my homeassistant pertty useless after 2 years of happy useage. Does anyone have the same issue?
No issues here, 13 has been great. Want to post your code so we can take a look? Though it’s probably a HA issue.
Node red has been updated, read the “documentation” tab, there is a config example.
Same, I tried the uninstall actionflows and it didnt work but turning off SSL seemed to do the job.
disable SSL worked for me, thanks!
Just got around the same error. And I find the message on the screen a bit misleading. So I set the log level to debug to find out what happened and it turned out that another node was failing that caused Node-Red to crash.
How do you do this. did a load of googling and no joy.
In the configuration of the Node Red installation page, you must set a Credential secret word and if your not using the Node Red for web content disable the SSL option. That should solve the issue of the 502 bad gateway message.
I am getting the 502 Gateway error when I click Deploy but it works every 3rd or 4th try. However, even when it works a simple flow which has 2 nodes Events All and Debug shows no messages.
