Can you give me more 101 type hints on how you did this? in HA it works… but I need to work this out in NodeRed … i’ve read everything I can but need more novice walk throughs.
Here is the export from NodeRed, you will need to switch the settings to your HASS instance, the yellow switch and the output nodes. In this case I’m only using two output nodes.
[{"id":"e0170ce8.fa7a58","type":"subflow","name":"HS 100 Dimmer Scenes","info":"","category":"","in":[{"x":120,"y":220,"wires":[{"id":"8297af3c.988b6"}]}],"out":[{"x":620,"y":60,"wires":[{"id":"d9a4564d.7ad7f","port":0}]},{"x":620,"y":100,"wires":[{"id":"d9a4564d.7ad7f","port":1}]},{"x":620,"y":140,"wires":[{"id":"d9a4564d.7ad7f","port":2}]},{"x":620,"y":180,"wires":[{"id":"d9a4564d.7ad7f","port":3}]},{"x":620,"y":240,"wires":[{"id":"2b06bd7f.980cf2","port":0}]},{"x":620,"y":280,"wires":[{"id":"2b06bd7f.980cf2","port":1}]},{"x":620,"y":320,"wires":[{"id":"2b06bd7f.980cf2","port":2}]},{"x":620,"y":360,"wires":[{"id":"2b06bd7f.980cf2","port":3}]}],"env":[],"outputLabels":["Single tap on","Double tap on","Triple tap on","Tap and hold on","Single tap off","Double tap off","Triple tap off","Tap and hold off"]},{"id":"8297af3c.988b6","type":"switch","z":"e0170ce8.fa7a58","name":"Scene ID","property":"payload.event.scene_id","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":260,"y":220,"wires":[["d9a4564d.7ad7f"],["2b06bd7f.980cf2"]]},{"id":"d9a4564d.7ad7f","type":"switch","z":"e0170ce8.fa7a58","name":"Scene Data","property":"payload.event.scene_data","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":430,"y":180,"wires":[[],[],[],[]],"outputLabels":["Single tap on","Double tap on","Triple tap on","Tap and hold on"]},{"id":"2b06bd7f.980cf2","type":"switch","z":"e0170ce8.fa7a58","name":"Scene Data","property":"payload.event.scene_data","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":430,"y":260,"wires":[[],[],[],[]],"outputLabels":["Single tap off","Double tap off","Triple tap off","Tap and hold off"]},{"id":"8e016187.d2dd38","type":"api-call-service","z":"27863c3f.28956c","name":"Offce light on","server":"db6dabc2.b30178","service_domain":"light","service":"turn_on","data":"{\"entity_id\":\"light.lights_office\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":835,"y":204,"wires":[[]]},{"id":"7cf3dc58.8477dc","type":"api-call-service","z":"27863c3f.28956c","name":"Office lights off","server":"db6dabc2.b30178","service_domain":"light","service":"turn_off","data":"{\"entity_id\":\"light.lights_office\"}","render_data":false,"mergecontext":"","output_location":"payload","output_location_type":"msg","x":835,"y":384,"wires":[[]]},{"id":"9cde9b8b.c1a028","type":"comment","z":"27863c3f.28956c","name":"Instructions!","info":"Only need to change the yellow switch and the outputs.","x":127.5,"y":151,"wires":[]},{"id":"d91e13e0.5cad48","type":"server-events","z":"27863c3f.28956c","name":"ZWave Scenes","server":"db6dabc2.b30178","event_type":"zwave.scene_activated","x":137,"y":319,"wires":[["bef4c632.882be8"]]},{"id":"bef4c632.882be8","type":"switch","z":"27863c3f.28956c","name":"Office Dimmer","property":"payload.event.entity_id","propertyType":"msg","rules":[{"t":"eq","v":"zwave.lights_office","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":317,"y":319,"wires":[["d3da6ba4.e6b2f"]],"outputLabels":["Ericas Switch"]},{"id":"d3da6ba4.e6b2f","type":"subflow:e0170ce8.fa7a58","z":"27863c3f.28956c","name":"","env":[],"x":545,"y":319,"wires":[["8e016187.d2dd38"],[],[],[],["7cf3dc58.8477dc"],[],[],[]]},{"id":"db6dabc2.b30178","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open"}]
And here’s the subflow node if it didn’t come through with the above.
[{"id":"8297af3c.988b6","type":"switch","z":"e0170ce8.fa7a58","name":"Scene ID","property":"payload.event.scene_id","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":260,"y":220,"wires":[["d9a4564d.7ad7f"],["2b06bd7f.980cf2"]]},{"id":"d9a4564d.7ad7f","type":"switch","z":"e0170ce8.fa7a58","name":"Scene Data","property":"payload.event.scene_data","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":430,"y":180,"wires":[[],[],[],[]],"outputLabels":["Single tap on","Double tap on","Triple tap on","Tap and hold on"]},{"id":"2b06bd7f.980cf2","type":"switch","z":"e0170ce8.fa7a58","name":"Scene Data","property":"payload.event.scene_data","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":430,"y":260,"wires":[[],[],[],[]],"outputLabels":["Single tap off","Double tap off","Triple tap off","Tap and hold off"]}]
Lastly, keep in mind I’m using first gen HS dimmers. If you’re using the newer 2nd gen you will need to update the dimmer scene numbers.
Thanks for replying… someones already contributed to it. Searching for nodered inovelli things i found this… which includes the scene ID and scene data and explains why the button down (Scene Id = 1) and button up (Scene id == 2) scenes are organised how they are. Genius!
nodered subflow for switches with scene id and data parameters
Hi folks from the future.
Here is an updated scene subflow for Openzwave for the Inovelli Red Dimmer. I also swapped outputs to up would be on top. Cheers.
keywords: ozw, LZW31-SN
[{"id":"8411e384.fb1f9","type":"subflow","name":"Inovelli Scenes","info":"","category":"","in":[{"x":120,"y":220,"wires":[{"id":"1adf8d0e.cac7f3"}]}],"out":[{"x":680,"y":40,"wires":[{"id":"3faf3597.ea43ba","port":0}]},{"x":680,"y":80,"wires":[{"id":"3faf3597.ea43ba","port":1}]},{"x":680,"y":120,"wires":[{"id":"3faf3597.ea43ba","port":2}]},{"x":680,"y":160,"wires":[{"id":"3faf3597.ea43ba","port":3}]},{"x":680,"y":200,"wires":[{"id":"3faf3597.ea43ba","port":4}]},{"x":680,"y":240,"wires":[{"id":"eee43bc5.cec848","port":0}]},{"x":680,"y":280,"wires":[{"id":"eee43bc5.cec848","port":1}]},{"x":680,"y":320,"wires":[{"id":"eee43bc5.cec848","port":2}]},{"x":680,"y":360,"wires":[{"id":"eee43bc5.cec848","port":3}]},{"x":680,"y":400,"wires":[{"id":"eee43bc5.cec848","port":4}]},{"x":680,"y":440,"wires":[{"id":"7247d146.a727a","port":0}]}],"env":[],"color":"#DDAA99","outputLabels":["Single tap up","Double tap up","Triple tap up","Quad tap up","5 taps up","Single tap down","Double tap down","Triple tap down","Quad Tap down","5 taps down","Config tap"]},{"id":"1adf8d0e.cac7f3","type":"switch","z":"8411e384.fb1f9","name":"Scene ID","property":"payload.event.scene_id","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"3","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":260,"y":220,"wires":[["eee43bc5.cec848"],["3faf3597.ea43ba"],["7247d146.a727a"]]},{"id":"eee43bc5.cec848","type":"switch","z":"8411e384.fb1f9","name":"Scene Value (Down)","property":"payload.event.scene_value_id","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"5","vt":"str"},{"t":"eq","v":"6","vt":"str"},{"t":"eq","v":"7","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":460,"y":260,"wires":[[],[],[],[],[]],"outputLabels":["Single Tap Down","Double Tap Down","Triple Tap Down","Quad Tap Down","5 Tap Down"]},{"id":"3faf3597.ea43ba","type":"switch","z":"8411e384.fb1f9","name":"Scene Value (Up)","property":"payload.event.scene_value_id","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"5","vt":"str"},{"t":"eq","v":"6","vt":"str"},{"t":"eq","v":"7","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":450,"y":180,"wires":[[],[],[],[],[]],"outputLabels":["Single Tap Up","Double Tap Up","Triple Tap Up","Quad Tap Up","5 Tap Up"]},{"id":"7247d146.a727a","type":"switch","z":"8411e384.fb1f9","name":"Scene Value (Config)","property":"payload.event.value_id","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":460,"y":320,"wires":[[]],"outputLabels":["Single Config Tap"]}]
For anyone looking for updates, it looks like discussion has been moved to [TIP] Home Assistant + Node-Red Scene Manager - Digital Lounge - Inovelli Community
Thanks guys this helped a lot. I found I can use the debug node to copy the path for the triple filter.
Switch node msg.payload.event.node_id
== the node number in debug
Switch node msg.payload.event.label
== scene in the debug window
Switch node msg.payload.event.value
== value in the debug ie Keypressed2X
These 3 nodes will filter out all the rest of the scenes. I just found out most wall switches have double pressed scene triggers built in.
Again. Thanks for getting the ball rolling.
