Similar thing happened to me as well. HA and NR are both on bridge. The IP I used for HA on NR however was the docker 17.n.n.n IP. It would work for a few minutes and then would get ‘not connected’ errors for the same flow. I then changed the HA IP in NR to use host:8123 and it worked better. Weird thing is it only happened on entities connected via mqtt.
New Release v0.10.1
Bug Fixes
api: Fix for saving locationType (bd20bfa)
call-service: Fix for having undefined output location and type (3a0d8b0)
wait-until: fixed scope for setContextValue (3fdfa27)
Features
api: Allows input to set/override config values (7296cd2), closes #100
Able to reference entity in comparators (ece176b)
api: Output type added to http api: binary, json,txt (9305c7d)
events-all: Added states_loaded and services_loaded (b8097b8)
events-all: Will includes HA client events (ccf9fbc), closes #75
get-entities: Added total count of entities as an output option (3061151)
render-template: Added custom outputs (66d504d)
Hi @Kermit, thanks a lot for your great work! Could you maybe explain a little bit how to use the states_added event? Because I added states_loaded
to the Event Type field of an events: all
node, but I cannot get it to work. The node doesn’t seem to filter and spits out all events
A new event_type, home_assistant_client, was added for client events, the node-red home assistant module, these include:
- connecting - when trying to connect to HA
- connected - after the authorization has been accepted
- disconnected - when the socket stops attempting to connect or disconnected after having been connected
- error - when a disconnect happens of the websocket with an error
- states_loaded - the first time all states are loaded from HA
- services_loaded - the first time all services are loaded from HA
[{"id":"959319c4.b4ed08","type":"server-events","z":"5eb3594f.d294b8","name":"","server":"ef067c6f.620e6","event_type":"home_assistant_client","x":328,"y":704,"wires":[["ced91c7f.a3e17"]]},{"id":"ced91c7f.a3e17","type":"debug","z":"5eb3594f.d294b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":546,"y":704,"wires":[]}]
Thank you so much! I must have completely missed that somehow Got it up and running now perfectly!
Thumbs up on making the template node’s outputs customizable!
I’m having an issue with the call-service node where, even though the Service is hard-coded (‘turn off’), it seems to be inheriting payload.service (e.g. from a previous call-service execution). Is there any chance this could be a bug with the call-service node implementation, wherein it prioritizes the inheritance of payload.service over a hardcoded Service value?
The issue I’m running into -
Overwriting “hard-coded” config values of a node is sort of a node-red paradigm. In the “Turn Garage Lights On” call-service node set the Output Location
to something other than msg.payload
or None
if you don’t really care about the data.
Hi @Kermit ant thanks for adding new features to this node!
states_loaded and services_loaded will not be shown after each restart, but only the first time HA will start from a new installation, right?
@Kermit Hi,
Love the addon, have a really big bug/feature request (haha, unsure which one it is),
“Current_State” node cannot get entity_id from msg.payload and has to be hardcoded (getting ‘value cannot be empty’ error if I leave it empty, and putting {{payload}} or msg.payload doesn’t work)
is there any way to push the entity_id from the payload?
thanks
As version 0.10.2 states_loaded and services_loaded will fire each time a successful connection is made to Home Assistant. When a connection is made the module requests all states and services from HA and when it has receives them it will fire the events.
If you leave the entity id field empty and pass in msg.payload.entity_id
this should work.
[{"id":"5a4d366e.cf57f8","type":"api-current-state","z":"5eb3594f.d294b8","name":"","server":"ef067c6f.620e6","outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":432,"y":480,"wires":[["52d2042f.08a0ac"]]},{"id":"1fb2a9e6.981176","type":"inject","z":"5eb3594f.d294b8","name":"","topic":"","payload":"{\"entity_id\": \"sun.sun\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":274,"y":480,"wires":[["5a4d366e.cf57f8"]]},{"id":"52d2042f.08a0ac","type":"debug","z":"5eb3594f.d294b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":614,"y":480,"wires":[]}]
@Kermit I’was only getting the connected state and no loaded ones.
I just noticed the new upgrade to 0.10.2 and now it’s working! Thanks
@Kermit
Its not working for me, I’m getting the entity_id from a “current_state” before this one, like this:
Summary
“id”: “8741c85.f218d38”,
“type”: “tab”,
“label”: “Remove Head Test”,
“disabled”: false,
“info”: “”
“id”: “fff8a14a.6627a”,
“type”: “inject”,
“z”: “8741c85.f218d38”,
“name”: “”,
“topic”: “”,
“payload”: “”,
“payloadType”: “date”,
“repeat”: “”,
“crontab”: “”,
“once”: false,
“onceDelay”: 0.1,
“x”: 93.53969192504883,
“y”: 116.79364013671875,
“wires”: [
“51930236.4de0fc”
“id”: “bd5a42d9.89781”,
“type”: “debug”,
“name”: “”,
“active”: true,
“tosidebar”: true,
“console”: false,
“tostatus”: false,
“complete”: “payload”,
“targetType”: “msg”,
“x”: 1121.71435546875,
“y”: 170.42857360839844,
“wires”:
“id”: “51930236.4de0fc”,
“type”: “api-current-state”,
“name”: “”,
“server”: “2757cc6a.31a344”,
“outputs”: 1,
“halt_if”: “”,
“halt_if_type”: “str”,
“halt_if_compare”: “is”,
“override_topic”: false,
“entity_id”: “input_text.currenthead”,
“state_type”: “str”,
“state_location”: “payload”,
“override_payload”: “msg”,
“entity_location”: “data”,
“override_data”: “msg”,
“x”: 329,
“y”: 204,
“wires”: [
“25efe6a0.75759a”
“id”: “bf79784b.05e2f8”,
“name”: “”,
“outputs”: 1,
“halt_if”: “”,
“entity_id”: “”,
“x”: 841,
“y”: 234,
“wires”: [
“bd5a42d9.89781”
“id”: “25efe6a0.75759a”,
“type”: “function”,
“name”: “”,
“func”: “var entity_id = msg.payload;\nmsg.payload = "{\"entity_id\":\"input_text."+entity_id+"\"}";\nreturn msg;”,
“outputs”: 1,
“noerr”: 0,
“x”: 595.5,
“y”: 215,
“wires”: [
“bf79784b.05e2f8”,
“9ee3fb1b.5ccdb8”
“id”: “9ee3fb1b.5ccdb8”,
“type”: “debug”,
“name”: “”,
“active”: true,
“tosidebar”: true,
“console”: false,
“tostatus”: false,
“complete”: “false”,
“x”: 794.5,
“y”: 132,
“wires”:
“id”: “2757cc6a.31a344”,
“type”: “server”,
“z”: “”,
“name”: “Home Assistant”,
“legacy”: false,
“hassio”: true,
“rejectUnauthorizedCerts”: true,
“ha_boolean”: “y|yes|true|on|home|open”,
“connectionDelay”: true
in the function (json is escaped in code):
msg.payload = “{"entity_id": "input_text.”+entity_id+“"}”;
return msg;
still getting
““value” is not allowed to be empty”
Use
msg.payload = {
entity_id: `input_text.${msg.payload}`
return msg;
or
const entity_id = msg.payload
msg.payload = {
entity_id: "input_text." + msg.payload
return msg;
awesome, it works!
thanks!
Hi @Kermit,
Sorry if it has been asked before but do you really need to use get template before a message call service in order to put that state into a message?
Example:
"id": "f4b7b8b1.d0c9c",
"type": "api-call-service",
"z": "1325b9db.a8ecb6",
"name": "Message",
"server": "e5e437c7.ff14c",
"service_domain": "notify",
"service": "michael",
"data": "{\"message\":\"Airco will turn off in {{ states.input_number.airco_slider.state | int }} minutes \"}",
"mergecontext": "",
"output_location": "payload",
"output_location_type": "msg",
"x": 220,
"y": 60,
"wires": [
"e84c7d7.4f3058"
[{"id":"1325b9db.a8ecb6","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"f4b7b8b1.d0c9c","type":"api-call-service","z":"1325b9db.a8ecb6","name":"Message","server":"e5e437c7.ff14c","service_domain":"notify","service":"michael","data":"{\"message\":\"Airco will turn off in {{ states.input_number.airco_slider.state | int }} minutes \"}","mergecontext":"","output_location":"payload","output_location_type":"msg","x":220,"y":60,"wires":[["e84c7d7.4f3058"]]},{"id":"e84c7d7.4f3058","type":"debug","z":"1325b9db.a8ecb6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":370,"y":60,"wires":[]},{"id":"a55342d8.f7c7b8","type":"inject","z":"1325b9db.a8ecb6","name":"Inject","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":60,"wires":[["f4b7b8b1.d0c9c"]]}]
No, you can access states directly from the call-service node. Review the info panel of the call-service node for a more detailed explanation.
make the data
field of the call-service node
{"message":"Airco will turn off in {{states.input_number.airco_slider}} minutes "}
Thanks you helped me into the right direction!
I have been using states.input_number.airco_slider.state instead of states.input_number.airco_slider
I’m stuck again and need a little help
I’m trying a call service for a set_value for input_text and I want to set the data in the payload.
I’ve tried all of these (escaped JSON):
msg.payload.data = “{“value”:”"+flow.get(‘wantedhead’)+""}";
msg.data = “{“value”:”"+flow.get(‘wantedhead’)+""}";
msg.data = flow.get(‘wantedhead’);
msg.payload.data = flow.get(‘wantedhead’);
msg.data = {
value: ${flow.get('wantedhead')}
msg.payload.data = {
msg.payload = {
return msg;
getting
“Call-service API error. Error Message: required key not provided @ data[‘value’]”
on all of them, what i am doing wrong?
I am new to node-red so excuse me if i am asking stupid questions.
I am not using hass.io so node-red installed separately from HA and I use access token.
Two things:
- Why “events:state” node have two outputs? Uper one seems to pass events, but lower one not.
- When/how list of entyties updated from HA. I added new switch to HA and then restarted HA. But the switch not apeared in list of entities of “events:state” when I type.
