and my next guess would be that the timestamp field of the service doesn’t accept templates. You can use a moment node before the call-service node and use { "datetime": "{{payload}}"}
ok thanks
I tried that and it works perfectly, even probably simpler to adapt!
Just finally migrated over to this from the LLAT node after procrastinating for about a year
Works a treat and the migration was quite easy. Thanks @Kermit for all your hard work.
I’m trying your example but get an error in the debug window of
"Call-service API error. Error Message: must contain at least one of temperature, target_temp_high, target_temp_low."
Just using a inject node with a value of 18. What could I be missing?
You’re trying to extract msg.payload from msg. Just use payload in that field
Release of Documentation
The groundwork for external documentation is in place:
https://zachowj.github.io/node-red-contrib-home-assistant-websocket/
That’s looking good
So I’ve been using this node happily for a while on a node red server running separately from my HA instance .
A couple of days ago I migrated to a NUC and am now running Node Red as a Hassio Addon .
After importing all my flows everything works flawlessly except for this node and my sensors no longer receive the updates in HA .
When Node Red is running from my original install the values update normally but after importing the flows to this new Node Red install the sensors won’t update anymore even though I can see all the values changing in the flow .
Any clue on what might be wrong ? Would really rather not have to create new sensors all over again as I have a lot of sensor templates tied to these … @Kermit ?
Edit : Just realized I am getting this error : “Sensor update attempted without connection to server.”
Apparently it creates new sensor entities after importing the flow, I suppose no way to keep the same entities as before ?
In tracing through my connection issues, it appears it’s related to this websocket library.
@Kermit, Any insight into why?
Node-Red disconnects and never reconnects after a debug “dump” happens with [object Object]
1 Jan 10:38:06 - [info] [server:Home Assistant] WebSocket Closed http://hassio/homeassistant
1 Jan 10:38:06 - [debug] [server:Home Assistant] config server event listener closed
1 Jan 10:38:11 - [debug] [server:Home Assistant] WebSocket Connecting http://hassio/homeassistant
1 Jan 10:38:11 - [debug] [server:Home Assistant] config server event listener connecting
1 Jan 10:38:11 - [debug] [server:Home Assistant] [object Object]
1 Jan 10:38:11 - [debug] [server:Home Assistant] config server event listener closed
I’m running NR 5.0.7, within a Dockerized environment on a NUC PC.
PS: Looks like it might be this line of code, nodes/config-server/config-server.js:289:
onHaEventsError(err) {
this.setOnContext('isConnected', false);
this.debug(err);
err
is an object unable to be properly decoded by the log handler.
^^ Node-Red Addon. It’s the version of the Docker container: https://github.com/hassio-addons/addon-node-red/releases
The UI, however, is showing 1.0.3:
OK. So it’s the version for the add-on, which isn’t the Node Red version, or Node Red’s Docker version. Got it. Had me confused for a minute.
Teehee… My efforts to decode the object didn’t work. Seems to be an anonymous function:
1 Jan 11:23:10 - [debug] [server:Home Assistant] WebSocket Connecting http://hassio/homeassistant
1 Jan 11:23:10 - [debug] [server:Home Assistant] config server event listener connecting
(node:915) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
at JSON.stringify (<anonymous>)
at ConfigServerNode.onHaEventsError (/opt/node_modules/node-red-contrib-home-assistant-websocket/nodes/config-server/config-server.js:291:29)
Good news is I was right as to the location of the error. How can we see what this error is?
Did you create your token and add it in, etc for your connection to Home Assistant?
I logged in directly via Docker cli. Edited the file, restarted nodered
via s6
. In-line editing, baby.
Unfortunate (or fortunately?) HA’s Addon “Restart” downs and recreates the container - blowing away any local changes.
It would appear the err object is not an error object. That’s why it’s difficult to pin-down, nothing is shown. It’s an HaWebsocket object.
Still no clue as to why the connection is closing.
The best I can figure out, at some point a reconnect-error
is triggered by the polling tick. This then starts a down-stream of errors, not captured anywhere. The best I can see is this might be a home-assistant-js-websocket
bug – failing to properly pass the resulting error? However, I can’t trace that as it’s all uncompiled .ts
libraries on the filesystem.
root@a0d7b954-nodered:/var/run/s6/services$ ls -l /opt/node_modules/home-assistant-js-websocket/lib/connection.ts
ls: /opt/node_modules/home-assistant-js-websocket/lib/connection.ts: No such file or directory
total 40
-rw-r--r-- 1 root root 10480 Oct 26 1985 LICENSE.md
-rw-r--r-- 1 root root 17875 Oct 26 1985 README.md
drwxr-xr-x 1 root root 4096 Jan 1 13:05 dist
-rw-r--r-- 1 root root 2365 Dec 17 05:20 package.json
root@a0d7b954-nodered:/var/run/s6/services$ ls -l /opt/node_modules/home-assistant-js-websocket/dist
total 308
-rw-r--r-- 1 root root 1177 Oct 26 1985 auth.d.ts
-rw-r--r-- 1 root root 832 Oct 26 1985 collection.d.ts
-rw-r--r-- 1 root root 597 Oct 26 1985 commands.d.ts
-rw-r--r-- 1 root root 217 Oct 26 1985 config.d.ts
-rw-r--r-- 1 root root 2409 Oct 26 1985 connection.d.ts
-rw-r--r-- 1 root root 330 Oct 26 1985 entities.d.ts
-rw-r--r-- 1 root root 240 Oct 26 1985 errors.d.ts
-rw-r--r-- 1 root root 12025 Oct 26 1985 haws.es.js
-rw-r--r-- 1 root root 70597 Oct 26 1985 haws.es.js.map
-rw-r--r-- 1 root root 12076 Oct 26 1985 haws.js
-rw-r--r-- 1 root root 70307 Oct 26 1985 haws.js.map
-rw-r--r-- 1 root root 12120 Oct 26 1985 haws.umd.js
-rw-r--r-- 1 root root 70301 Oct 26 1985 haws.umd.js.map
-rw-r--r-- 1 root root 446 Oct 26 1985 index.d.ts
-rw-r--r-- 1 root root 1184 Oct 26 1985 messages.d.ts
-rw-r--r-- 1 root root 223 Oct 26 1985 services.d.ts
-rw-r--r-- 1 root root 133 Oct 26 1985 socket.d.ts
-rw-r--r-- 1 root root 628 Oct 26 1985 store.d.ts
-rw-r--r-- 1 root root 2569 Oct 26 1985 types.d.ts
-rw-r--r-- 1 root root 64 Oct 26 1985 util.d.ts
Here’s a full trace of the onClientError() event trigger:
1 Jan 13:23:10 - [debug] [server:Home Assistant] config server event listener connecting
Trace: o {
options:
{ setupRetry: 0,
createSocket: [Function: createSocket],
self:
HaWebsocket {
_events: [Object],
_eventsCount: 13,
_maxListeners: 0,
config: [Object],
connectionState: 0,
states: [Object],
services: [Object],
statesLoaded: false,
client: [Circular],
subscribedEvents: [Set],
unsubCallback: [Object],
integrationVersion: 0,
servicesLoaded: false } },
commandId: 11,
commands:
Map {
2 => { resolve: [Function],
reject: [Function],
callback: [Function],
subscribe: [Function: subscribe],
unsubscribe: [Function: unsubscribe] },
3 => { resolve: [Function],
reject: [Function],
5 => { resolve: [Function],
reject: [Function],
6 => { resolve: [Function],
reject: [Function],
8 => { resolve: [Function],
reject: [Function],
9 => { resolve: [Function],
reject: [Function],
11 => { resolve: [Function],
reject: [Function],
unsubscribe: [Function: unsubscribe] } },
eventListeners:
Map {
'ready' => [ [Function: bound onClientOpen],
[Function: u],
[Function: u],
[Function: u] ],
'disconnected' => [ [Function: bound onClientClose] ],
'reconnect-error' => [ [Function: bound onClientError] ] },
closeRequested: false,
socket:
WebSocket {
_events:
[Object: null prototype] { message: [Function], close: [Function] },
_eventsCount: 2,
_maxListeners: undefined,
readyState: 3,
protocol: '',
_binaryType: 'nodebuffer',
_closeFrameReceived: true,
_closeFrameSent: true,
_closeMessage: '',
_closeTimer:
Timeout {
_called: false,
_idleTimeout: -1,
_idlePrev: null,
_idleNext: null,
_idleStart: 74563,
_onTimeout: null,
_timerArgs: undefined,
_repeat: null,
_destroyed: false,
[Symbol(unrefed)]: false,
[Symbol(asyncId)]: 1783,
[Symbol(triggerId)]: 1358 },
_closeCode: 1000,
_extensions: { 'permessage-deflate': [PerMessageDeflate] },
_receiver:
Receiver {
_writableState: [WritableState],
writable: false,
_events: [Object: null prototype] {},
_eventsCount: 0,
_extensions: [Object],
_maxPayload: 104857600,
_bufferedBytes: 0,
_buffers: [],
_compressed: true,
_payloadLength: 2,
_mask: undefined,
_fragmented: 0,
_masked: false,
_fin: true,
_opcode: 8,
_totalPayloadLength: 0,
_messageLength: 0,
_fragments: [],
_state: 0,
_loop: false,
[Symbol(websocket)]: [Circular] },
_sender:
Sender {
_socket: [Socket],
_firstFragment: true,
_compress: false,
_bufferedBytes: 0,
_deflating: false,
_queue: [] },
_socket:
Socket {
connecting: false,
_hadError: false,
_handle: null,
_parent: null,
_host: 'hassio',
_readableState: [ReadableState],
readable: false,
_events: [Object],
_eventsCount: 2,
writable: false,
allowHalfOpen: false,
_sockname: null,
_pendingData: null,
_pendingEncoding: '',
server: null,
_server: null,
parser: null,
_httpMessage: null,
timeout: 0,
write: [Function: writeAfterFIN],
[Symbol(asyncId)]: 1358,
[Symbol(lastWriteQueueSize)]: 0,
[Symbol(timeout)]: null,
[Symbol(kBytesRead)]: 40143,
[Symbol(kBytesWritten)]: 1010,
[Symbol(websocket)]: undefined },
_bufferedAmount: 0,
_isServer: false,
_redirects: 0,
url: 'ws://hassio/homeassistant/websocket',
_req: null },
_ent:
{ state: [Getter],
refresh: [Function: c],
subscribe: [Function: subscribe] },
_srv:
{ state: [Getter],
_cnf:
{ state: [Getter],
subscribe: [Function: subscribe] } }
at HaWebsocket.callback [as onClientError] (/opt/node_modules/node-red-contrib-home-assistant-websocket/lib/ha-websocket.js:266:10)
at forEach (/opt/node_modules/home-assistant-js-websocket/lib/connection.ts:153:7)
at Array.forEach (<anonymous>)
at o.fireEvent (/opt/node_modules/home-assistant-js-websocket/lib/connection.ts:152:48)
at /opt/node_modules/home-assistant-js-websocket/lib/connection.ts:327:18
at process._tickCallback (internal/process/next_tick.js:68:7)
This is a dump of the result of this addition:
@node_modules/node-red-contrib-home-assistant-websocket/lib/ha-websocket.js:266
onClientError(data) {
console.trace(data);
this.closeClient(
data,
'events connection error, cleaning up connection'
The websocket object has a closeCode 1000, and according to the docs: this is a perfectly normal closure – https://developer.mozilla.org/en-US/docs/Web/API/CloseEvent
So, something else is broken.
Hi all,
Just a few days ago I noticed some weird behavior in my Node-Red and I cannot pin-point what the problem is (driving me mad ). So hoping someone can help me troubleshoot (Hass logs are not saying anything as well as Node-Red…).
Running Hass and Node-Red in a separate Docker.
I have this input_boolean in home-assistant to indicate if we are sleeping or not. It always has worked perfectly:
In some Node-Red flows I check the state of this Switch like so:
However, recently I’m getting the result “Initializing at: …” constantly on this boolean:
Does not matter if it’s On/Off, always the same result and treated as “false” by the node…
The debug shows as follows, the first line is the payload before it enters this node, second is the result “initializing”.
Am I missing something obvious??
@flamingm0e - according to HA Websocket’s documents, reconnect-error
is supposed to be only called on ERR_INVALID_AUTH
Looks like somewhere, somehow, the auth token is expiring? However, there is a bug in the websocket’s implementation. According to the docs reconnect-error
is supposed to pass the code not a websocket object.
This may very well be an HA bug (maybe?). NR hasn’t changed from what I can tell.
Kind of…
input_boolean.sleeping_global is a boolean and you are comparing its value to a string.
So, you are comparing “true” with “on” and it is always “false”.
Choose boolean in the drop down menu “if state”. It should be better.
GV
Turns out this IS due an auth error! – The debug()
messages within ha-websocket aren’t showing up in the logs, making it hard to debug this issue. I added my own commands and here we go:
[Auth Phase] New connection ws://hassio/homeassistant/websocket
1 Jan 14:08:38 - [debug] [server:Home Assistant] WebSocket Connecting http://hassio/homeassistant
1 Jan 14:08:38 - [debug] [server:Home Assistant] config server event listener connecting
[Auth Phase] Received { type: 'auth_required', ha_version: '0.103.5' }
[Auth Phase] Received { type: 'auth_ok', ha_version: '0.103.5' }
1 Jan 14:08:38 - [info] [server:Home Assistant] WebSocket Connected to http://hassio/homeassistant
1 Jan 14:08:38 - [debug] [server:Home Assistant] config server event listener connected
1 Jan 14:13:05 - [info] [server:Home Assistant] WebSocket Closed http://hassio/homeassistant
1 Jan 14:13:05 - [debug] [server:Home Assistant] config server event listener closed
events connection closed, cleaning up connection
[Auth Phase] Initializing ws://hassio/homeassistant/websocket
1 Jan 14:13:10 - [debug] [server:Home Assistant] WebSocket Connecting http://hassio/homeassistant
1 Jan 14:13:10 - [debug] [server:Home Assistant] config server event listener connecting
1 Jan 14:13:15 - [debug] [server:Home Assistant] WebSocket Connecting http://hassio/homeassistant
1 Jan 14:13:15 - [debug] [server:Home Assistant] config server event listener connecting
1 Jan 14:13:15 - [info] [server:Home Assistant] WebSocket Connected to http://hassio/homeassistant
1 Jan 14:13:15 - [debug] [server:Home Assistant] config server event listener connected
1 Jan 14:18:05 - [info] [server:Home Assistant] WebSocket Closed http://hassio/homeassistant
1 Jan 14:18:05 - [debug] [server:Home Assistant] config server event listener closed
1 Jan 14:18:10 - [debug] [server:Home Assistant] WebSocket Connecting http://hassio/homeassistant
1 Jan 14:18:10 - [debug] [server:Home Assistant] config server event listener connecting
[Auth Phase] Received { type: 'auth_invalid', message: 'Invalid access' }
I’ve opened up two tickets on this, first one is a real bug, other may be resolved some other way (?):
debug([...])
messages withinha-websocket.js
aren’t showing in the console: https://github.com/zachowj/node-red-contrib-home-assistant-websocket/issues/181 - Websocket dies on reconnect with
auth_invalid
: https://github.com/zachowj/node-red-contrib-home-assistant-websocket/issues/182
Now, I’m dead in the water. … NR can’t stay connected.
(*note: I can reconnect NR simply by manually redeploying the flows … but it won’t stay connected)
