First post here so be gentle
Is it possible to use node red to a standard installation of Home Assistant version 0.73.2, not a Hass.io installation? If so, how do i do that?
BR
Fredric
BR
Fredric
if you have node red installed go into palette and look for home assistant. I chose the web socket version but there are more options
I think that worked, i can see some home-assistant attributes now.
Thank you!
Just a noob question, did you use node-red-contrib-home-assistant?
EDIT, FYI: I trying something similar with MQTT:
Yes thats the one i installed.
