This fixed it for me, no more delays, thanks!
How do you changed the the NR configuration node for HA to the internal url? Can you share the configurations changues?.
Thanks,
Jose
Donāt use the Hue Magic node (node-red-contrib-huemagic). Itās slow!
As soon as I used the HA objects to interact with Hue devices, no lags anymore.
Maybe if you donāt use HA+Node-Red, you can use the Hue Magic without issuesā¦
Can you tell me howto split up node red an home assistant on a separate raspi?
Having mayor delay problems that i havend had before and would like to try this.
Iām no big coder, so iām using node red alot.
Thanks!
Yep. Iāve noticed that the issue is with NodeRed, specifically the output ābufferā where it sends data to HA via the āservicesā node, e.g. turn light onā¦
This seemed to start happening to me about a year ago, and since then I have run a script in NodeRed to restart itself. Sometimes I have to get this to happen once an hour, as over 2-3 hours the problem sets in.
