Node-RED Sunset/Sunrise Light Automations
Its called Big Timer, but I now discovered I should have started my “sequence” from the bottom output square instead of the top one. This one is great because in addition to time you can set a schedule based on time relative to sunrise or sunset (or a list of other parameters).
BTW, before I started I downloaded all of the “pallets” from this guy’s list. He recommends one named “Light Scheduler”. Which I haven’t played with much yet.
Oh, and if you are using Docker, make sure you have it configured to your time zone, or your lights will go off at the wrong time and you will be very confused for days. :wink:
