Nodes not showing up after renaming
I am configuring my zwave network and running into some issues.
The main issue I have now is that when i rename a Node in “Configuration --> Zwave --> Nodes” it works (the node is renamed). BUT it doesn’t show up in the node list anymore then, so i can’t rename it to somehting else.
How can I get these nodes back in the Zwave configuration?
Using 0.62.1 of HASS.
There are zwave issues with v 62 related to naming. I would use v 61 until it’s fixed in 63 hopefully
You have to restart after renaming nodes.
Did that mutliple times…
they still not appear in the Node list then.
Let me try with v61
ps @anderstbl where can i find there is an issue with zwave naming in 62? I have searched i thought everywhere before posting the problem i have :wink:
