Normalize Date and Time
So you’re talking about a very specific 1 off scenario of a dropdown when creating a notification service call?
I can’t answer that at this point; It’s the only thing I’ve tried to do.
I think you and OP are talking about very differnt things. You just want an easy way to output the current time into a message/notification. OP is talking about adding times together (calculations in templates), which is a pain.
I don’t think the functionality needs to follow the input field, perhaps built as helper tool? I don’t know, I’m just ‘spit balling’ at this point.
You’re correct.
Nodered does this all rather easily. As a code novice, timestamps are a nightmare. Nodered uses moment.js and you can send in almost any time format. Simply tell it how to output and if you need to add time/days.
