(Not) Possible to have BT + NFC on 1 ESP device?
I already had a Wemos D1 mini with a NFC reader which works fine.
Recently I installed a Wemos C3 to be able to use Bluetooth and got that working too.
Now I thought of adding the NFC reader to the C3 but an error scrolled by that only 1 api is ?possible/allowed? (don’t get that anymore)
Is it (not) possible to have those 2 functions on 1 device?
Yaml? Log?
esphome:
  friendly_name: Wemos C3 BT
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "key"
ota:
  password: "password"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Wemos-C3-Bt Fallback Hotspot"
captive_portal:
esp32_ble_tracker:
  scan_parameters:
    interval: 1100ms
    window: 1100ms
    active: true
bluetooth_proxy:
  active: true
i2c:
  sda: 4
  scl: 5
  scan: true
pn532_i2c:
  update_interval: 0.3s
  on_tag:
    then:
      - text_sensor.template.publish:
          state: !lambda 'return x;'
      - if:
          condition:
            text_sensor.state:
              state: 'XX-XX-XX-XX'
          then:
            - script.execute: person_1_detected
binary_sensor:
  - platform: status
# Text sensors with general information.
text_sensor:
  # For Tag.
    internal: true
    name: "Badge Recognized"
  # Expose ESPHome version as sensor.
  - platform: version
  # Expose WiFi information as sensors.
  - platform: wifi_info
    ip_address:
    ssid:
    bssid:
# Sensors with general information.
  # Uptime sensor.
  - platform: uptime
  # WiFi Signal sensor.
  - platform: wifi_signal
    update_interval: 60s
script:
  - id: person_1_detected
    mode: single
    then:
          state: !lambda 'return "Nick";'
      - delay: 400ms
          state: !lambda 'return "Clear";'
Thanks for looking into Nick!
Still waiting for logs, but I do notice your ble parameters are wrong. Those settings are only for wired Ethernet devices. See Bluetooth Proxy — ESPHome
Also don’t forget the c3 is a single core device, and may not be best suited to being a Bluetooth proxy.
This is the current log:
INFO ESPHome 2024.3.1
INFO Reading configuration /config/esphome/wemos-c3-bt.yaml...
INFO Starting log output from 172.16.0.48 using esphome API
INFO Successfully connected to wemos-c3-bt @ 172.16.0.48 in 0.064s
INFO Successful handshake with wemos-c3-bt @ 172.16.0.48 in 0.128s
[23:55:28][I][app:102]: ESPHome version 2024.3.1 compiled on Sep  3 2024, 22:26:24
[23:55:28][C][wifi:580]: WiFi:
[23:55:28][C][wifi:408]:   Local MAC: XX:XX:XX:XX:XX:XX
[23:55:28][C][wifi:413]:   SSID: 'ssid'[redacted]
[23:55:28][C][wifi:416]:   IP Address: 172.16.0.48
[23:55:28][C][wifi:420]:   BSSID: XX:XX:XX:XX:XX:XX[redacted]
[23:55:28][C][wifi:421]:   Hostname: 'wemos-c3-bt'
[23:55:28][C][wifi:423]:   Signal strength: -57 dB ▂▄▆█
[23:55:28][C][wifi:427]:   Channel: 1
[23:55:28][C][wifi:428]:   Subnet: 255.255.255.0
[23:55:28][C][wifi:429]:   Gateway: 172.16.0.1
[23:55:28][C][wifi:430]:   DNS1: 172.16.0.3
[23:55:28][C][wifi:431]:   DNS2: 0.0.0.0
[23:55:28][C][logger:166]: Logger:
[23:55:28][C][logger:167]:   Level: DEBUG
[23:55:28][C][logger:169]:   Log Baud Rate: 115200
[23:55:28][C][logger:170]:   Hardware UART: USB_CDC
[23:55:28][C][i2c.arduino:059]: I2C Bus:
[23:55:28][C][i2c.arduino:060]:   SDA Pin: GPIO4
[23:55:28][C][i2c.arduino:061]:   SCL Pin: GPIO5
[23:55:28][C][i2c.arduino:062]:   Frequency: 50000 Hz
[23:55:28][C][i2c.arduino:065]:   Recovery: bus successfully recovered
[23:55:28][I][i2c.arduino:075]: Results from i2c bus scan:
[23:55:28][I][i2c.arduino:077]: Found no i2c devices!
[23:55:28][C][template.text_sensor:020]: Template Sensor 'Badge Recognized'
[23:55:28][C][template.text_sensor:020]: Template Sensor 'Detected'
[23:55:28][C][uptime.sensor:031]: Uptime Sensor 'Uptime'
[23:55:28][C][uptime.sensor:031]:   Device Class: 'duration'
[23:55:28][C][uptime.sensor:031]:   State Class: 'total_increasing'
[23:55:28][C][uptime.sensor:031]:   Unit of Measurement: 's'
[23:55:28][C][uptime.sensor:031]:   Accuracy Decimals: 0
[23:55:28][C][uptime.sensor:031]:   Icon: 'mdi:timer-outline'
[23:55:28][C][bluetooth_proxy:088]: Bluetooth Proxy:
[23:55:28][C][bluetooth_proxy:089]:   Active: YES
[23:55:29][C][pn532:431]: PN532:
[23:55:29][C][pn532:443]:   Update Interval: 0.3s
[23:55:29][C][pn532_i2c:125]:   Address: 0x24
[23:55:29][C][status:034]: Status Binary Sensor 'Module Status'
[23:55:29][C][status:034]:   Device Class: 'connectivity'
[23:55:29][C][version.text_sensor:021]: Version Text Sensor 'ESPHome Version'
[23:55:29][C][version.text_sensor:021]:   Icon: 'mdi:new-box'
[23:55:29][C][esp32_ble:374]: ESP32 BLE:
[23:55:29][C][esp32_ble:376]:   MAC address: XX:XX:XX:XX:XX:XX
[23:55:29][C][esp32_ble:377]:   IO Capability: none
[23:55:29][C][esp32_ble_tracker:645]: BLE Tracker:
[23:55:29][C][esp32_ble_tracker:646]:   Scan Duration: 300 s
[23:55:29][C][esp32_ble_tracker:647]:   Scan Interval: 1100.0 ms
[23:55:29][C][esp32_ble_tracker:648]:   Scan Window: 1100.0 ms
[23:55:29][C][esp32_ble_tracker:649]:   Scan Type: ACTIVE
[23:55:29][C][esp32_ble_tracker:650]:   Continuous Scanning: True
[23:55:29][C][captive_portal:088]: Captive Portal:
[23:55:29][C][mdns:115]: mDNS:
[23:55:29][C][mdns:116]:   Hostname: wemos-c3-bt
[23:55:29][C][ota:096]: Over-The-Air Updates:
[23:55:29][C][ota:097]:   Address: wemos-c3-bt.local:3232
[23:55:29][C][ota:100]:   Using Password.
[23:55:29][C][ota:103]:   OTA version: 2.
[23:55:29][C][api:139]: API Server:
[23:55:29][C][api:140]:   Address: wemos-c3-bt.local:6053
[23:55:29][C][api:142]:   Using noise encryption: YES
[23:55:29][C][wifi_info:011]: WifiInfo SSID 'SSID'
[23:55:29][C][wifi_info:012]: WifiInfo BSSID 'BSSID'
[23:55:29][C][wifi_info:009]: WifiInfo IPAddress 'IP'
[23:55:29][C][wifi_signal.sensor:009]: WiFi Signal 'WiFi Signal'
[23:55:29][C][wifi_signal.sensor:009]:   Device Class: 'signal_strength'
[23:55:29][C][wifi_signal.sensor:009]:   State Class: 'measurement'
[23:55:29][C][wifi_signal.sensor:009]:   Unit of Measurement: 'dBm'
[23:55:29][C][wifi_signal.sensor:009]:   Accuracy Decimals: 0
I have almost turned the i-net upside down to get this working and finally, with these settings it works.
I didn’t know what to buy for this and I don’t know what the effect is in reality for being single core or multiple cores: it does the job so far.
I just wanted to be able to connect the NFC reader and as well have a BT receiver for a Shelly BLU button1
EDIT: this was the error regarding api
[E][bluetooth_proxy:439]: Only one API subscription is allowed at a time
Just pointing out what it says in the docs. Pleased it works for you.
Hard to find many references to that error. It is generated here
https://github.com/search?q=repo%3Aesphome%2Fesphome%20"Only%20one%20API%20subscription%20is%20allowed%20at%20a%20time"&type=code
So it’s easy to miss something when reading logs, but the log looks ok to me. Are you still having any problems?
Please don’t misunderstand me: I appreciate it very much that you pointed that out!
To me, this ESP stuff is new and getting into to it is learning new things, concepts, …
Even though afterwards it all seems so simple, it took me fairly some time, to get this C3 to install/flash.
BT works but NFC does not.
As you can see from the log no i2c device is found…
Yes, I have no clue how to go from here.
I have the D1 for some time now and got NFC working.
At that time, I had no plans for using BT but then I bumped on the Shelly BLU button1 so I ordered it & the C3 for it’s BT capability.
Getting the BLU button into HA didn’t go smooth but finally works.
Now, I wanted to combine those 2 (NFC & BT) into the C3, as a challenge but also because I find it stupid to have 2 devices when it can be done by 1.
Should it be possible to have 2 functions (these or any other, given the controller supports it) in 1 device?
Your comment about being single core: I have no idea what the effect is in my case. Can you elaborate a little on that?
They should work together, but the c3 is a comparatively weak device, and Bluetooth proxy is quite resource intensive so maybe it is too much for it.
You have Bluetooth constantly scanning which makes it difficult for wifi to work as they use the same chip. What ancillary effects that will have, I don’t know. I strongly suggest you follow the docs, ie esp_32_tracker parameters should be left at the defaults.
If that doesn’t work, try disabling the Bluetooth stuff and see if the nfc works.
You need to alternate ble and rest of the setup. Or use dual core board.
I use time based esp32_ble_tracker.start_scan and .stop_scan actions.
Also note:
