I think it would be a good idea if the automation would send an “all clear” when the state of the sensor is finally restored. Then you would know if e.g. the door was already shut by someone, or does it still need closing.
I’ve done this before, but opted to not include it into this blueprint. Take a look into “notification replacement” to avoid having notifications pile up and make a wait until trigger for when the door is closed again before sending a notification.
I wanted to express my gratitude for the fantastic work on the original blueprint. Inspired by @Neekster’s version, I’ve created an enhanced version with additional features and improvements. If you’re looking for:
Clear Notifications: Clear the notification when, for instance, a door or window has been closed again, so you know there’s no need to worry.
Flexible Notification Services: I’ve added the option to notify multiple devices directly without relying on notify groups. Simply list your desired notify services, separated by commas.
Input Boolean Support: Now you can use both binary_sensor and input_boolean domains as trigger entities.
Check out the extended blueprint here for more details. I am looking forward to your feedback!
