I have a working notification that sends a telegram-message about which doors or windows are open.
But how can I tweak this to only send the message IF something actually is open?
As an example, this is what it sends now:
If nothings is open: The following doors and windows are open: “”
Is something is open: The following doors and windows are open “Front door, bathroom window”
message: >-
Følgande dører og vinduer er opne! "{{ states | selectattr('entity_id', 'in',
state_attr('group.all_doors_and_windows','entity_id')) |
selectattr('state','in',['on','open']) | list | map(attribute='name') |
join(', ') }}"
How are you triggering your automation? It shouldn’t trigger when no door/window is open
. Please show the full automation.
We use booleans to turn on or off different “modes” or “scenes” in our house. Like “Home” or “God night” or “Gone”.
alias: Varsling dersom vinduer eller dører åpne
description: ''
- entity_id: input_boolean.godnatt
platform: state
to: 'on'
- entity_id: input_boolean.kjorer_hjemmefra
platform: state
to: 'on'
- entity_id: input_boolean.gaar_hjemmefra
platform: state
to: 'on'
- entity_id: input_boolean.ferie
platform: state
to: 'on'
- platform: state
entity_id: input_boolean.kveldskos
to: 'on'
condition: []
- data:
message: >-
'in', state_attr('group.all_doors_and_windows','entity_id')) |
join(', ') }}"
service: notify.telegram_daniel
- service: notify.telegram_anette
message: >-
join(', ') }}"
What kind of entities are in this group.all_doors_and_windows? Only binary_sensors or also sensors?
Only binary
all_doors_and_windows:
name: Dører og vinduer
icon: mdi:window-open-variant
entities:
- binary_sensor.inngangsdor
- binary_sensor.terrassedor
- binary_sensor.loftstuedor
- binary_sensor.garasjedor
- binary_sensor.dorinnigarasjen
- binary_sensor.kjoleskapssensor
- binary_sensor.vindu_vart_soverom
- binary_sensor.malinavindu
- binary_sensor.vindu_bad_oppe
- binary_sensor.kjokkenvindu_hogre
- binary_sensor.kjokkenvindu_venstre
- binary_sensor.kjokkenvindu_skulen
Ok, then try this:
description: ''
- entity_id:
- input_boolean.godnatt
- input_boolean.kjorer_hjemmefra
- input_boolean.gaar_hjemmefra
- input_boolean.ferie
- input_boolean.kveldskos
platform: state
to: 'on'
condition: state
entity_id: group.all_doors_and_windows
state: 'on'
- variables:
open_doors: "{{ expand('group.all_doors_and_windows')|selectattr('state', 'eq', 'on')|map(attribute='name')|list }}"
- service: notify.telegram_daniel
message: >-
Følgande dører og vinduer er opne! {{ open_doors }}
message: >-
If at least one window/door is open (at least one binary_sensor is on) then the group state will be ‘on’. So you can use the group state as a condition. I also tried to simplify/shorten your code.
Thank you so much for your time!
I get:
“Message malformed: invalid template (TemplateSyntaxError: expected token ‘end of print statement’, got ‘doors’) for dictionary value @ data[‘action’][2][‘data’]”
When trying to save it. Any pointers?
I have simply pasted it as a YAML-edit.
You solved my issue with something as simple as the condition.
I added it like this:
description: ''
platform: state
to: 'on'
platform: state
to: 'on'
platform: state
to: 'on'
platform: state
to: 'on'
- platform: state
to: 'on'
- condition: state
state: 'on'
- data:
message: >-
join(', ') }}"
message: >-
join(', ') }}"
But if your willing to use more time with your simplified / shortened code, I am interested !
The second message misses a _ between open and doors. I fixed it.
Thank you very much!
That did the trick!
