Wonder if someone can help, I’m suddenly getting the following error in my error log after the upgrade. It was working on 0.40 and I upgraded it all the way to 0.45.1. Now, obviously my notify 5 push notifications stopped working
I’m using Hassbian by the way and I’m quite new at this…
2017-05-23 22:22:40 ERROR (Thread-6) [homeassistant.util.package] Unable to install package pywebpush==1.0.0: Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-79l17yum/http-ece/
2017-05-23 22:22:40 ERROR (MainThread) [homeassistant.setup] Not initializing notify.html5 because could not install dependency pywebpush==1.0.0
2017-05-23 22:22:40 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform notify.html5: Could not install all requirements.
2017-05-23 22:22:40 ERROR (MainThread) [homeassistant.components.notify] Unknown notification service specified
These command (run from the venv, logged in as the HA user and with the venv activated) should tell you whether pywebpush and cryptography are installed:
pip list | grep pywebpush
pip list | grep cryptography
I think I got into the virtual environment of hassbian by looking through the docs, but when I ran your commands I got errors.
pi@hassbian:~ $ sudo su -s /bin/bash homeassistant
homeassistant@hassbian:/home/pi $ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@hassbian:/home/pi $ pip list | grep pywebpush
DEPRECATION: The default format will switch to columns in the future. You can use --format=(legacy|columns) (or define a format=(legacy|columns) in your pip.conf under the [list] section) to disable this warning.
(homeassistant) homeassistant@hassbian:/home/pi $ pip list | grep cryptography
Yeah I confirmed last night it was 0.45.1 that broke the notify html5 notifications. I re-flashed back to 0.40 and notify html5 worked. As soon as I upgraded Hassbian to the latest release, which is currently 0.45.1, rebooted, and notify html5 stopped working.
Thanks I will check this out.
I wanted to use html5 because I didn’t want to have to manage another app on my phone. Usually browsers will take care of it. I’m running windows/chrome and android/chrome so I think I meet the requirements of Zanzito.
I have a MQTT server on my pi for OwnTracks presence detection, just not encrypted though… (which is something I still need to figure out)
Not on an Android device. It comes up in notifications. But on a desktop browser, unless you have Chrome options to let it run in the background as a tray app for notifications, then you are correct.
Question is, how do I install it on hassbian?
Do I need to log into a virtual environment?
And then run the sudo apt-get install libpython-dev libffi-dev libssl-dev?
Edit: I tried doing the above and it asked for a password for Hassbian. I don’t know what the password is… I tried all my passwords and nothing worked.
pi@hassbian:~ $ sudo apt-get install libpython-dev libffi-dev libssl-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
libffi-dev is already the newest version.
libpython-dev is already the newest version.
libssl-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 13 not upgraded.
pi@hassbian:~ $ sudo apt-get install pywebpush
E: Unable to locate package pywebpush
I must be typing the command in wrong to get pywebpush…
These were the instructions I got from Robbie - the dev - who helped me to get it running in a Gitter chat.
Maybe they’ll help?
1. Shutdown Home Assistant
2. If you use a virtual environment (virtualenv/venv), activate it.
3. pip uninstall pywebpush
4. pip install "https://github.com/web-push-libs/pywebpush/archive/e743dc92558fc62178d255c0018920d74fa778ed.zip#pywebpush==0.5.0"
5. Start up Home Assistant
6. Attempt to send a notification over HTML5.
pi@hassbian:~ $ pip install "https://github.com/web-push-libs/pywebpush/archive/e743dc92558fc62178d255c0018920d74fa778ed.zip#pywebpush==0.5.0"
-bash: pip: command not found
This was a cut and paste from the chat - let me check but I think that should be pip3 if you are running in the venv.
EDIT: Went back and reread the entire chat transcript and only pip was mentioned but I did do it all with the venv activated so it may be that I just didn’t correct him or ask because I was a 4 month noob at the time in a chat with a core dev. LOL Was trying to give @robbiet480 due respect. And it was such a great intro to how nice this community was (is) that a core dev - who at the time was managing a point release at the same damn time - would take time out to help some noob fix his setup.
I really think that should be pip3 since you are in a Python 3 environment when the venv is activated.
