Look at alerts - you might want to consider those…
Also consider in your automation that sends the notification, you can also set whatever value you want into a helper, and then in that same automation put a condition. The helper can be the last time the notification was sent, and the condition used later can check the value against the current time. For example I have some automations that have a condition so they do not take place if a timestamp in an input_text helper (it would not work with datetime helpers for some reason so I used input_text and never bothered to go back and figure out why) - was less than 5 minutes ago. For example, if I manually turn off the basement laundry ceiling light, that timestamp I would place into an input_text named input_text.last_manual_off_basement_laundry_ceiling. Then my condition to take an action would not proceed if it had been turned off manually within the last 5 minutes - had this code:
Note, the datetime comparison I found only seemed to work if both values were converted to floats before comparing them (to see if the difference was more than 300 seconds).
Thanks for your response. I attempted creating some helpers and the condition you mentioned. I’m still missing something I think. I guess I really didn’t understand how to create an input_text helper as you suggested, but it got me thinking.
I created the threshold sensor with a lower limit of 25 and then came up with last triggered as the condition in the automation. Does something like this make sense?
Threshold sensor
entity_id: sensor.gw2000b_feels_like_temperature
hysteresis: 0
lower: 25
position: below
sensor_value: 17
type: lower
upper: null
friendly_name: Feels Like Under 25
Settings (in the sidebar) → Devices and services → Helpers (tab on top) → “+Create Helper” button in the bottom right corner → then pick “text” from the list of helper types.
My code to populate the helper (for the above example) looks like this, in the action part of an automation:
(FYI: Don’t worry about “sensor[‘basement_laundry_ceiling_light_off_context’]” for this example, that is a template sensor I have that will if you ask send you down a rabbit hole with a long explanation of something unrelated. Suffice it to say that almost every sensor has a “.last_changed” property which is a linux timestamp value.)
Hey @genomez , I just discovered in reading through the forums, something already built for us for time comparisons used in HA… the “timedelta(…)” function! So for example instead of:
Well, I’m clearly totally lost. As a reminder, I’m trying to get a notification for when my weather station reports a Feel’s Like temperature of under 25 degress (in this example), but without spamming me when it wobbles between over and under.
I’ve created a threshold sensor that reports “on” when the temperature drops below 25 degrees and “off” above 25 degrees. That works and sends the notification properly, but I get too many notifications.
I’ve tried many different things so I thought I’d post the full automation yaml in hopes you see whatever the dumb mistake is. It’s driving me crazy! Thanks for all the help and looking at this mess!
description: ""
triggers:
- trigger: state
entity_id:
- binary_sensor.last_time_feels_like_under_25
conditions:
- condition: template
value_template: >-
{{ now() - as_datetime(states('input_text.last_time_feels_like_under_25'))
> timedelta(minutes=5) }}
enabled: true
actions:
- action: input_text.set_value
metadata: {}
value: last_changed
entity_id: input_text.last_time_feels_like_under_25
enabled: true
- action: script.notify_mobile_app_devices_2024_08
metadata: {}
notify_devices:
- 327f7595e3a9b
data_notification_icon: mdi:temperature-fahrenheit
notify_title: Weather Station
notify_message: Feel's Like Temperature is below 25°
data_group: Weather
data_channel: Weather
data_importance: high
data_clickaction: sensor.ecowitt_outdoor_temperature
mode: single
Thanks for the suggestion. I considered the hysteresis function and that might be ok for a regular temperature notification. The problem I could see with Feel’s Like Temperature is it can swing so far in short periods of time. If I used ‘5’ as an example, that would lower the notifications, but it flucuates so much it would still be noisy. If I set it to ‘10’ that would help for windy days, but then limit it for calmer days.
That’s why I’ve been trying to figure out a way to simply (obviuosly not so simple) throttle/mute/snooze that notification for X amount of time. It sounds simple, but it clearly isn’t (at least for me). I assumed if I could figure it out for this one I could then incorporate it into other notifications.
I tried adding a hysteresis value of 5 to test and let it run overnight. It helped, but I still received 33 notifications. I guess I’ll try a value of 10 this time.
I thought I’d post a follow up to let you know what I did, just in case someone stumbles by this and wants an idea of one of the many ways to do it. It’s the best I could come up with for now. I created a threshold helper and a timer helper. I currently have the timer set to 10 minutes, but might adjust that. I’m certainly open to suggestions if anyone has some. Thank you!
Here is the full yaml.
alias: Feel's Like Notification Test
description: ""
triggers:
- trigger: state
entity_id:
to: "on"
conditions:
- condition: state
entity_id: timer.feels_like_notify_timer
state: idle
enabled: true
actions:
- action: timer.start
metadata: {}
data: {}
metadata: {}
notify_devices:
- 327f7595e3a9b
notify_message: >-
Another-Feel's Like Temperature is low:
{{(states('sensor.gw2000b_feels_like_temperature'))}}{{state_attr('sensor.gw2000b_feels_like_temperature',
'unit_of_measurement')}}
data_group: Weather
data_clickaction: sensor.gw2000b_feels_like_temperature
mode: single
What am I missing here? Installed the blueprint. Created a test script. Tested it out in developers tools with some parameters. How does the yaml that gets created get associated with the script? In other words how do I link the two so I can call the scipt with the data in an automation?
This Blueprint is a script, so once downloaded and imported you will have an new script like: script.name_that_you_used_to_import_it . Next up is to go to your automations or other scripts and use it as an action
Ahh, Thanks. The opening description only talked about testing it in dev tools. I think it would of been better to test it using a trigger where you set the values and then just run the action. Then you don’t have to copy the settings from testing to the trigger. First time I had a script from a blueprint so i was a bit confused. Thanks.
This script has started flaking out on me. If I try to Run Action from an automation of this script, it gives the error “Device not connected to local push notifications” This means that the device of some family member is not set up for it, or is not home, or something, idk. Then, no notifications are sent to any device. Is it possible to change the script so that all of the notifications are sent in parallel, such that one rogue device doesn’t bork all the notifications?
Ah… Well that shouldn’t happen indeed… There is a single argument that should be included that should solve this. Could you create an issue on GitHub? And please provide a screenshot of the trace of the script
I have updated the script but when I run a test it keeps telling me ‘action notify_mobile_app_adrian_s_xxx not found’ this used to work fine. However there is a notify_mobile_app_adrians_xxx which works fine.
Is there maybe an apostrophe “‘“ confusing the script - any suggestions on how to fix
Unsure, I’m running into this issue myself. It seems to have an issue if the name for the device_tracker isn’t the same as the name for the notifiy service. This happened even though I deleted the entire O11 mobile device and readded it.
But I manually renamed the device_tracker entity and now it works fine.
