Notify person
This feature request thread brought this 5 year HA lurker out of the shadows to create an account.
Please don’t forget about this one guys. Targeting people and all their associated devices for notifications would be huge for increasing user engagement.
Right now, using notifications for users is pretty cumbersome. You need to duplicate the message you want to send for each user.
It would be nice if there was a more streamlined notification system that effectively let you do bulk notifications and more easily attach information like photo captures from cameras, or statuses from entities, etc.
Having an automation that lets you “notify” and you just checkbox the users and the message and data would be ideal.
Especially if you can then allow users themselves to determine how they want to be notified (whether a push notification, in app, or muted, etc)
Would a notification group not fulfill this part?
Here’s a workaround until this becomes a supported feature. In short, using customize.yaml you can associate notify services with each person entity. Then you can reference those in automations or scripts.
Step 1: Edit your customize.yaml file (see here for details) and list each person and their associated notification services that you’d like to use. For example:
person.john_doe:
  notify_services:
    - 'notify.mobile_app_johns_iphone'
    - 'notify.custom_notify_service_for_john'
person.jane_doe:
  notify_services:
    - 'notify.mobile_app_janes_android'
Then restart so it takes effect. (There are ways to reload this file without restarting and those methods are discussed in the docs; I won’t cover them here.)
Step 2: Utilize those new attributes in your automations & scripts. Here is an example script that will call every notify service attached to every person who is currently home:
alias: Alert everyone who is home
continue_on_error: true
sequence:
  - variables:
      notify_services: >
        {{ state_attr('zone.home','persons') | map('state_attr','notify_services') | sum(start=[]) | list }}
  - repeat:
      for_each: "{{ notify_services }}"
      sequence:
        - service: "{{ repeat.item }}"
            message: You are home!
mode: single
I specify continue on error in case a notify service is removed or renamed; this way all the other notifications are still sent. You will still see errors in your logs if that happens though.
Edit: here’s a simpler option if you are OK with restricting yourself to only one notify service per person.
Example of customize:
person.john_doe:
  notify_service: notify.mobile_app_johns_iphone
person.jane_doe:
  notify_service: notify.mobile_app_janes_android
Example of how to notify everyone who is home:
sequence:
  - variables:
      notify_services: >
        {{ state_attr('zone.home','persons') | map('state_attr','notify_service') | list }}
  - repeat:
      sequence:
mode: single
And where it becomes easier is if you only want to notify a single person. Instead of
  message: "Hello John!"
You can use this instead:
service: "{{ state_attr('person.john_doe', 'notify_service') }}"
The benefit is that you never have to maintain your automations or scripts if you decide that you want to be notified by a different method. Or if you change your phone and your notification method changes. It’s a single change to the customize YAML.
BUMP!
This is so important! In my case I have a guest user account that I give to visitors. (obviusly I change the PW inbetween visitors). This means that the devices accosiated with the user account changes frequently and sometimes this account is logged in on multiple devices. It needs to be possible to broadcast notifications to all devices where a certain account is logged in without having to manually add devices!
For those still searching for a solution:
I made this script for myself, it takes a message and a list of people and sends notifications to their devices. If no people are specified it defaults to everyone.
It works perfectly for me, but I did not test it with multiple devices for the same person, so I don’t know what it’ll do in that case.
alias: Notifier script
description: Send notifications to the devices of the specified people.
fields:
  title:
    selector:
      text: null
    description: The title of the notification
    default: Notification
    required: true
  message:
    selector:
      text: null
    description: The message to send
    example: Generic notification. Something happened.
    required: true
  people:
    selector:
      text:
        multiple: true
    description: The list of people to notify
sequence:
  - variables:
      everyone: >-
        {{ states.person | map(attribute='entity_id') | map('replace',
        'person.', '') | list }}
      recipients: "{{ people if people | length > 0 else everyone }}"
  - repeat:
      for_each: "{{ recipients }}"
      sequence:
        - if:
            - condition: template
              value_template: "{{ repeat.item in everyone }}"
          then:
            - variables:
                person_entity: person.{{ repeat.item | lower }}
                device_name: >
                  {% set source = state_attr(person_entity,'source') %} {{
                  source.split('device_tracker.')[-1] if source != None else
                  None }}
            - if:
                  value_template: "{{ device_name != None }}"
              then:
                - data:
                    title: "{{ title }}"
                    message: "{{ messaggio | default('Generic notification. Something happened.')  }}"
                  action: notify.mobile_app_{{ device_name }}
              else:
                - action: system_log.write
                    level: warning
                    message: >-
                      The person "{{ repeat.item }}" has no linked devices, unable to notify.
                    logger: notifier_script
          else:
                level: warning
                message: >-
                  The person "{{ repeat.item }}" doesn't exist, unable to notify.
I love that multiple automations for tracking don’t need to be modified when a device has changed if I am using a person entity to trigger the actions. Unfortunately I don’t have the same with notifications without having to set it up in YAML with notify groups. In addition to notify groups, being able to add devices to a person would be really convenient to have so tracking and notifications can all be handled from a single location.
Just having changed one device, +1 to this! I proposed even a bit more advanced notification handler in here. Managing efficient alerting/notifications through UI is a bit frustrating.
This feels very similar to the new change in 2026.4 where you can just say “when movement in area” and it just looks at all the movement sensors in that area automatically, so you never need to worry about changing automations.
like that, but for devices/person.
