Nuki Card with Callback support (supports both Lock & Opener, it replaces the official integration)
if it is ONLY accessible through https, since the bridge only supports http, you can’t use the callback.
You need to use NGINX Home Assistant SSL proxy: “typically used to forward SSL internet traffic while allowing unencrypted local traffic to/from a Home Assistant instance.”
This is off-topic for this thread, but you will find a lot of threads in the forum regarding this configuration. Check this post, as an example.
