Try this new integration : GitHub - kvj/hass_nuki_ng: Better support for Nuki devices in the Home Assistant
For me it was not necessary to fill the âWeb Api tokenâ. If you not need it for some special moves in HA, then keep it empty.
I just filled in the âBridge Api tokenâ and everything went fine.
As far as I understand, @OrTiN is asking why nuki_ng isnât a part of Home Assistant core integration (bundled)? I have no idea how and by whom official integration is maintained and their affiliation with Nuki.
Yepp, you got the point. The core nuki should be updated basing on your code. Works like a charm!
The official Nuki integration has the following code owners:
I donât think theyâre officially affiliated with Nuki at all. Indeed, from my perspective it would make sense to combine forces as many issues and feature requests related to the official integration are actually solved by nuki_ng
There is no affiliation between Nuki and the HA official integration so I donât see any reason any contribution would not be welcome implementing Nuki NG modifications to the official integration would benefit for Home Assistant itself by making the existing integration near perfect.
Problem solved
Hey. Did someone come up withe the reason for that âdoor sensor jammedâ issue? Itâs now happening every 2 days that I have to reset the door sensor (worked fine for months with this extension).
The fact that the NUKI company itself is now recommending the HACS over the official integration should prompt for a reconsideration of the official integration, shouldnât it?
Hello, after updating HomeAssistant to newest version today, the Nuki integration is failing and not connecting to Bridge
