Using Home Assistant (2022.11.2 - Doker) and NUT (0.11.0) on Raspberry PI3 (Buster), I want to supervised my Network UPS (S2S Syrius MS 6000 from Legrand - ms_ii_en.pdf) thanks to SNMP protocol.
I used the following pameter for the NUT Configuration:
My UPS is equipped with a CS 131 Network card (manual_CS121_en.pdf) with RJ45 output.
I used the SNMP protocol V3 as show below, according to the manual to monitore the CS121 the Standard-MIB for UPS-systems, RFC1628, is generally to be integrated into your NMS.
By the way, NUT doc shows compatible MIBS with the RFC 1628: ietf
Here the log file error:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-banner.sh
Add-on: Network UPS Tools
Manage battery backup (UPS) devices
Add-on version: 0.11.0
You are running the latest version of this add-on.
System: Raspbian GNU/Linux 10 (buster) (armv7 / raspberrypi3)
Home Assistant Core: 2022.11.3
Home Assistant Supervisor: 2022.10.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/02-set-timezone.sh
[22:38:41] INFO: Configuring timezone
cont-init: info: /etc/cont-init.d/02-set-timezone.sh exited 0
cont-init: info: running /etc/cont-init.d/nut.sh
[22:38:42] INFO: Setting mode to netserver...
[22:38:42] INFO: Generating /etc/nut/upsd.users...
[22:38:43] INFO: Configuring user: admin
[22:38:46] INFO: Password is NOT in the Have I Been Pwned database! Nice!
[22:38:49] INFO: Configuring Device named S2S_6000...
[22:38:49] INFO: Starting the UPS drivers...
Created directory: /var/lib/snmp/cert_indexes
Startup timer elapsed, continuing...
Network UPS Tools - UPS driver controller 2.7.4
cont-init: info: /etc/cont-init.d/nut.sh exited 1
cont-init: info: running /etc/cont-init.d/nutclient.sh
cont-init: info: /etc/cont-init.d/nutclient.sh exited 0
cont-init: warning: some scripts exited nonzero
s6-rc: warning: unable to start service legacy-cont-init: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Are you running NUT server add-on through home assistant or directly on the raspberry pi os? your config is a little different layout to mine (mine through nut server add-on in home assistant). I recall I had issues with the layout when first setting up as the documentation wasnt right for my setup and through some trial and error the below worked
Thank you very much, I transpose your example and it work like a charm now !
By the way, is there a way to get a switch button onto HA in oorder to swtich from battery mode to the AC mode ?
I am not familiar with that UPS to know the features unfortunately. If theres an API or way to do this via serial or web interface then I’m sure there should be a way to do this. This will be seperate to the NUT server/client setup though.
Add-on version: 0.12.0
System: Home Assistant OS 10.3 (amd64 / qemux86-64)
Home Assistant Core: 2023.6.3
Home Assistant Supervisor: 2023.06.2
Cyberpower - SHA/AES
APC - MD5/DES
- name: ups-PR2000RTXL2U
driver: snmp-ups
port: 192.168.1.10
snmp_version: v3
secLevel: authPriv
authProtocol: SHA
authPassword: 0123456789ABCDEF
privProtocol: AES
privPassword: 0123456789ABCDEF
pollfreq: 15
desc: description does not work
config: []
- name: ups-apc-x2200
driver: snmp-ups
port: 192.168.1.11
snmp_version: v3
secLevel: authPriv
authProtocol: MD5
privProtocol: DES
config: []
My UPS is available using SNMP but this addon shows UPS as not detected during startup.
How can I provide additional MIB file (mib: triplite 1.54) so my UPS using driver: snmp-ups is detected?
(after Going back to the classic MIB detection method.) log message
I have set Eaton 5E 850iUSB yesterday on HAOS, Nut server + integration.
Prior to that connected it to windows machine and checked for newer firmware (2.0.65 or smt). Its been about 18 hours since.
Ups itself seems to have great parameters (line interactive, usb management), but still its on the cheap end… I would not be surprised to find out the control board just died.
Today i have to replace old battery, will report afterwards.
After few days since battery replacement is everything Ok. 5E 850 serves as a sensor for home power outages and backs up Home Assistant Green with router.
Now its configured to send SMS notifications instead of beeping.
I really did not expected such old hardware to be effective part of smart home.
