Hi, the solution of usin a0d7b954-nut
as host works on HA integration but I can’t reach the nutserver from other client devices in the network. To read data from the qnap NAS I need to set the IP address of the nutserver. Is there any solution?
Thanks in advance
Thank you for that!
I had exactly the same problem, the auto discovered NUT integration was not working, but after I ignored it and configured a new one manually then it showed all four fields and it worked at last.
