And ofcourse you can also use the Plex component in Home Assistant. Then Home Assistant can also show media info.
Thank you!
I am using both; the media_player for android tv and the plex sensor. Here are both current states:
media_player.nvidia_shield paused
volume_level: 1
is_volume_muted: false
app_id: com.plexapp.android
app_name: Plex
source: hdmi
adb_response: null
friendly_name: nVIDIA Shield
supported_features: 21945
media_player.plex_shield_android_tv playing
media_content_id: 20290
media_content_type: movie
media_duration: 6114
media_position: 129
media_position_updated_at: 2019-11-15T11:55:02.129026+00:00
media_title: In the Tall Grass (2019)
app_name: Movies
media_content_rating: null
session_username:
media_library_name: Movies
friendly_name: Plex (SHIELD Android TV)
entity_picture: /api/media_player_proxy/media_player.plex_shield_android_tv?token=
supported_features: 21301
When I toggle pause, the plex sensor will change its status to paused
, however, the media_player will always stay on paused
(and when I toggle again, it will not change to playing
, either). The really big issue for me is this: let’s say I am watching something on plex and pause it; now I assume that my lights will go on. However, when I then watch something on youtube/netflix and pause it, the plex sensor will be paused
or idle
(as I am not currently using plex but another app), while the media_player entity will either be playing
or paused
. Now, I’d like my lights to toggle regardless what app I am watching on, as long as it’s state changes from playing
to paused
. But if I need two separate entities for the automation (or a condition), this will get kinda confusing.
In other words: I would expect the media_player.nvidia_shield
entity to change its status to playing
when something is playing on plex as this means it is also playing on the shield at the same time (because plex is running on that device).
Oke, if you wan’t to change the lights regardless of the app that is playing your best bet is to use the status of the AndroidTV component mediaplayer. Otherwise you have to get quite complex with conditions (like you already mentioned… ). I don’t use plex myself but i also see that the status doesn’t work correct with specific apps.
Did you see the new “Custom State Detection” in the androidTV component ? I haven’t tried it myself but it seems that you can add rules for specific apps. Maybe that can solve your issue. I the example configuration there’s an entry for Plex.
I just looked at them, but don’t quite understand how to work with them (will have to read slowly once more )
Below are my updated automations; I would assume they’d work, but they don’t. Also, I had a condition like
condition: state
entity_id: media_player.plex_nvidia_shield_android_tv
state: "unavailable"
in the rule for the shield itself (so that the plex sensor will not mess with the playing/paused status for anything but plex itself), but that doesn’t work at all. Also, the media_player.plex_nvidia_shield_android_tv
entity does only then exist when it is running; once I close plex, the entity disappears until I start it again, making it very difficult (for me!) to work with that entity all together).
Therefore, I removed that condition. Now when I toggle play/pause, nothing happens with any of those lights. I noticed that sometimes!! the media_player.nvidia_shield
entity will toggle the status after I toggled it; however, sometimes this takes over half a minute, sometimes even longer, sometimes it won’t change states at all.
((usually when watching a movie and pausing, it’s to grab some water or for a bathroom break, so I cannot wait about a minute for the lights to turn on might as well be back by then))
automation:
- id: 'light_plex_pause'
alias: "[Licht] Plex Pause"
- platform: state
entity_id: media_player.plex_shield_android_tv
to: "paused"
- service: python_script.light_store
store_name: sz_nachttisch
entity_id: light.schlafzimmer_innr_light
store_name: sz_bett
entity_id: light.schlafzimmer_led_bett
store_name: sz_leiste
entity_id: light.sz_led_seite
- service: light.turn_on
rgb_color: [255, 176, 67]
brightness: 55
transition: 5
color_temp: 500
rgb_color: [255, 255, 255]
brightness: 50
transition: 5
effect: "None"
brightness: 50
transition: 5
effect: "static"
- id: 'light_plex_resume'
alias: "[Licht] Plex Resume"
- platform: state
to: "playing"
store_name: sz_bett
operation: restore
operation: restore
operation: restore
- id: 'light_plex_off'
alias: "[Licht] Plex Aus"
- platform: state
to: "unavailable"
- service: pythong_script.light_store
store_name: sz_bett
operation: restore
operation: restore
operation: restore
- id: 'light_shield_pause'
alias: "[Licht] Shield Pause"
- platform: state
entity_id: media_player.nvidia_shield
to: "paused"
store_name: sz_bett
brightness: 55
transition: 5
color_temp: 500
brightness: 50
transition: 5
effect: "None"
brightness: 50
transition: 5
effect: "static"
- id: 'light_nvidia_resume'
alias: "[Licht] Nvidia Resume"
- platform: state
to: "playing"
store_name: sz_bett
operation: restore
operation: restore
operation: restore
I don’t use Plex, but as @hvdheurik suggested, I think the answer is to use custom state detection. Try the example from the full configuration in the documentation. You can also use this python script to help you to determine what the rules should be.
Thank you everybody! I used the example from full configuration copying exactly what was listed for plex.
For some reason, it kinda works now, but not in a way that I can work with:
- OK = start plex app (state: standby)
- OK = start playback in plex (state: playing)
- OK = pause playback in plex (state: paused)
- OK = start playback again (state: playing)
- ERROR = pause playback again (STILL state: playing)
- OK = stop playback completely while still in plex (state: standby)
So I can once get a paused
state via media_player.nvidia_shield
, but after that, it will not pick up paused
again until I stop playback, start playback, and then pause.
These transitions take about 10 seconds. While this is similar in other apps (netflix, for example), those other apps will report paused
each time that I actually pause. Only plex will not do this.
Might this sluggish behaviour (about 10 seconds for state update) have to do with my WiFi? Or is this a normal time periode? Also, when I switch apps, their app_id (for example de.prosiebensat1digital.seventv
) takes considerably less than 10 seconds to update; so changing apps is reported more frequently than play state???
This is my config atm
# Kommandos siehe auch hier
# https://github.com/JeffLIrion/python-androidtv/blob/bf1058a2f746535921b3f5247801469c4567e51a/androidtv/constants.py#L143-L186
# {{{ nVIDIA Shield TV
media_player:
- platform: androidtv
host: !secret nvidia_host
adb_server_ip: !secret adb_server_ip
adb_server_port: !secret adb_server_port
get_sources: true
device_class: auto
apps:
com.netflix.ninja: "Netflix"
com.google.android.tvlauncher: "Homescreen"
com.google.android.youtube.tv: "YouTube"
com.zdf.android.mediathek: "ZDF"
de.rtli.tvnow: "RTL Now"
com.amazon.amazonvideo.livingroom: "Amazon Video"
de.prosiebensat1digital.seventv: "Joyn"
# turn_on_command: "input keyevent 3"
# turn_off_command: "input keyevent 223"
state_detection_rules:
'com.netflix.ninja':
- 'media_session_state'
'com.plexapp.android':
- 'paused':
'media_session_state': 3 # this indentation is important!
'wake_lock_size': 1 # this indentation is important!
- 'playing':
- 'standby'
'com.amazon.avod':
- 'playing':
'wake_lock_size': 4 # this indentation is important!
- 'playing':
'wake_lock_size': 3 # this indentation is important!
- 'paused':
'wake_lock_size': 2 # this indentation is important!
- 'paused':
- 'standby'
The Android TV component polls for an update every 10 seconds.
You could try to fine tune your state detection rules, but I think a better approach is to use both entities as triggers for your automation. My syntax will probably be wrong, but something like:
automation:
- platform: state
entity_id:
- media_player.plex_shield_android_tv
- media_player.plex
to: "paused"
- condition: template
value_template: >
{% if is_state('media_player.plex', 'unavailable') %}
true
{% elif trigger.to_state.entity_id == 'media_player.plex' %}
true
false
Hi there,
I’ve got the same problem since the upgrade to v0.101. It wasn’t working either in 0.99 and there was a discussion somewhere that I took part in where the issue was found and fixed in 0.100. If I use Plex and even other apps that provide video playback, the Android TV media player is stuck on paused. I had the automation that dims the lights working so well only when the Plex app was used and now it is not working any more.
I would prefer if owners of the Nvidia Shield or any Android TV device can chime in and confirm this? Perhaps we need to log an issue on Github, but the more that report the same behavior, makes the logging of the issue a bit more palatable.
@JeffLIrion thank you. I will try this later. An issue that might occur again is that sometimes plexes state might be playing, while nvidia_shield is still at paused (even though it is actually playing, as plex is playing). So the automation might still not know what to do as both entities have opposite states…?
Also, I tried using your script, but could not figure out how to. When I run it from “developer tools” => “services”, I don’t get any output… However, since I am using the exact example from full configuration, shouldn’t it just work™ ? The states should be correct as they are taken directly from the example.
@ipodmusicman I think that is a good idea! I have not reported an issue on Home Assistant github yet, but perhaps you could do this and link to this post? I am willing to provide any logs that might help to figure this out.
I did notice this morning that while playing YouTube, the status displayed correctly while on Plex, it was not. I just need to check if other video playing apps are displaying the same behavior or if it is a Plex only situation.
The condition
will use the state of the Plex media player and ignore state changes in the Android TV media player when Plex is running.
Did you provide service data to the script, as the corresponding documentation indicates? You could change logging.info
to logging.critical
There is no issue. The logic for determining the state can vary between devices, so if you want it to report the correct state then you have to determine the correct custom state detection rules for a given app on your device.
@ JeffLIrion the thing is that this worked flawlessly in 0.100 and I didn’t need to put in special logic for special states at all.
I tested other apps on the Shield and they work just fine. YouTube, Spotify, Netflix and even DSTV Now (our local pay TV network’s streaming app). It is only when Plex is playing on the Shield, that the status shows as Paused which is rather odd. I know that Plex received an update on Android TV not too long ago, so not sure if this is either coincidence or not.
The state detection logic in the androidtv
package differs for each app. The logic for Plex that’s in the current HA version hasn’t changed in a long time, although it will change in HA 0.104 to the logic captured by the state detection rules in the full configuration example. So it could be that the Plex app changed, or it could be that something else changed on your Android TV device.
Came looking since I have the same problem with states!
Bought a new Shield TV to replace my old rpi solution, for me it’s like this
Start plex and start playing = status playing
Pauses = status paused
Resumes playing = status paused
On the card in the frontend of hass It shows as paused, pressing the play button does start the playback and I can toggle it from home-assistant but the card never updates to playing nor the status.
I believe this is a problem in communication between shield and hass. I am currently playing video on the shield via amazon prime video app. It had been paused, but is playing now, still those lights (that are supposed to be during pause only on due to the automation I wrote) are still on.
Then again, plex seems to sometimes work correctly now. Toggling play and pause positively did toggle those lights most of the time, but not all the time.
We could still use this workaround and run play inside of kodi, because this seems to report the play / pause state immediately (quicker than any other app on the shield and / or firetv, though that might just be the personal impression I got), but just the fact that it ought to work without a workaround makes me not want to do this (besides , the key app on android tv is pretty decent and doesn’t require one to use kodi as a “middleman”).
Do all of you shield users get the “source” drop down menu in Home Assistant? On my firetv, I can, for example, start the YouTube app from Home Assistant via this drop down menu, yet it is entirely missing on the media_player.shield entity (regardless of the extra settings from the docs page I have tried).
This wasn’t explained as clearly as I thought in the documentation, so I submitted a pull request to update it.
The Android TV integration works by polling the Android TV / Fire TV device at a regular interval and collecting a handful of properties. Unfortunately, there is no standard API for determining the state of the device to which all apps adhere. Instead, the backend
androidtv
package uses three of the properties that it collects to determine the state:audio_state
,media_session_state
, andwake_lock_size
. The correct logic for determining the state differs depending on the current app, and the backendandroidtv
package implements app-specific state detection logic for a handful of apps. Of course, it is not feasible to implement custom logic for each and every app in theandroidtv
package. Moreover, the correct state detection logic may differ across devices and device configurations.The solution to this problem is the
configuration parameter, which allows you to provide your own rules for state detection.…
Hi folks,
This was fixed in 0.103 of HA. All is good in the world now.
Sorry to dig up an old thread, but I ran into this today, and figured I might as well post my configuration in case somebody will need it in the future. This is for Shield Pro:
media_player:
scan_interval: 1
host: 192.168.1.156
exclude_unnamed_apps: true
"org.xbmc.kodi":
- "playing":
"media_session_state": 2
"wake_lock_size": 2
- "paused":
"wake_lock_size": 1
- "standby":
"media_session_state": 1
"wake_lock_size": 1
"com.netflix.ninja":
- "media_session_state"
"com.amazon.amazonvideo.livingroom":
- "playing":
"media_session_state": 3
"wake_lock_size": 3
- "paused":
"wake_lock_size": 1
- "standby":
"media_session_state": 0
"wake_lock_size": 1
"com.disney.disneyplus":
- "playing":
"wake_lock_size": 3
- "paused":
"wake_lock_size": 1
- "standby":
"wake_lock_size": 0
It works well enough to turn on/off lights when you pause and resume playing in any of the apps above. There are some quirks, like, for example, fast forwarding in amazon prime videos app is considered a “pause”, but it otherwise it works well.
Oh, and Disney+ initial state actually reports media_session_state
as null
, which is not supported by HomeAssistant configuration, since it expects an integer.
Sorry to dig this up again, but the androidtv media player doesn’t work properly for me on my shield with plex.
If I run this to get the status of the shield:
service: androidtv.adb_command
command: GET_PROPERTIES
I get the following in the media_player attributes:
adb_response: >-
{'screen_on': True, 'awake': True, 'audio_state': 'paused', 'wake_lock_size':
2, 'current_app': None, 'media_session_state': None, 'audio_output_device':
None, 'is_volume_muted': None, 'volume': None, 'running_apps': None,
'hdmi_input': None}
As you can see, it says that the shield isn’t running any app, despite it actively playing a video in plex.
Is anyone else seeing this? Thanks
