when i was using this component, the memory usage kept going up into multiple GBs. when I stopped using it the memory usage came back normal (~250mb). I am not a developer so dont want to draw uninformed conclusions based out of my limited testing. If and when you get memory leak concerns from other seasoned users, you may look into this. cheers.
edit: never mind. it is still going up. may be something else causing this.
Great job on this. I’d previously written this guide for use with TensorFlow. However, I’ve been playing around with Hass.io which doesn’t easily support it. Recreated the flows using this plug-in without any issues. Great job!
An example config for 4 cameras and automation example would be greatly appreciated to get this beginner up and running. I would like to detect vehicles and people when motion is detected on any of the cameras.
Thank you in anticipation…
HI,
Wanted to ask if this would be possible to use this somehow to detect a U.S. Postal vehicle (kinda like a jeep but all white with red and blue stripes across the middle), namely as it stops-at/drives-by my mailbox in front of my house?
Its 5000 per month, so if I did the math right its free around 1 scan per each 9 minutes, correct? (1 month is max 31 days * 24 hours * 60 minutes=44.640 minutes / 9 is 4960
My cameras detect motion but my image_processing stays as “Unknown”. I think I am not getting set Keys correctly, tried several times but nothing works.
There is this error:
WARNING (MainThread) [hassio.updater] Can’t fetch versions from https://s3.amazonaws.com/hassio-version/stable.json: Cannot connect to host s3.amazonaws.com:443 ssl:True [SSLCertVerificationError: (1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1056)’)]
You are using a custom integration for amazon_rekognition which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
