Occupancy Blueprint
Hey @docNeptun ,
you can use the wasp helper as a trigger for further automations. Just choose as a trigger type State and search for the helper (bathroom_wasp), then you can choose the state changes (off → on for movement and on → off for no movement [as two separate triggers]).
There are also some blueprints that can help you to achieve the light dimming behaviour. Currently, I use a modified version of the default motion blueprint. I also plan to publish my version as soon as I have the time to polish it. Presently, it’s not in a state to be published.
Update: It was not the default motion blueprint. I used the following blueprint as a template: Turn on light, switch, scene, script or group based on motion, illuminance, sun (+ more conditions)
