Offer option to loop/repeat an audio file on the media_player.play_media service
Would love a native way to do this. For those that don’t want to mess with scripts if you install music assistant this generates new media players (duplicates of your current ones including nest speakers) and allows you to send the command media repeat all command which will loop the audio. Benifit is thistle doesn’t get caught up in loops or interrupted. You can even pause and play and it will playing on loop.
Your seven-step process worked for me too based on testing; thank you very much for the cheat sheet. Haven’t set up completely to use at night because it took me a while to get working. It wasn’t working at first, but then realized in logs wasnt triggering, so added a trigger to go with the ‘while’ time range in step 5.
It’s been some time, but would you mind sharing the code? I am pretty new to home assistant and your explanation was not enough for me to get this up and running.
Spent far too much time trying to get this right so thought I would document it here.
Here is what I did:
  1. created a automation which implements the while loop when a light switch is switch on:
The problem I was having was if I stopped the mp3 playing then I had to wait until the delay had run down before I could re-start the mp3.
So I created another automation which does the following steps:
  1. stops the audio
  2. Turn off the first automation
  3. Turn on the first automation
Code for first automation:
alias: play2
description: Play music when the light comes on
  - platform: state
    entity_id:
      - light.picture_leds_switch_1
    to: null
condition: []
  - choose:
      - conditions:
          - condition: state
            entity_id: light.picture_leds_switch_1
            state: "on"
        sequence:
          - repeat:
              sequence:
                - service: media_player.play_media
                    entity_id: media_player.office_speaker
                    media_content_id: >-
                      media-source://media_source/local/04-Won't Fight Your
                      War.mp3
                    media_content_type: audio/mpeg
                  metadata:
                    title: 04-Won't Fight Your War.mp3
                    thumbnail: null
                    media_class: music
                    children_media_class: null
                    navigateIds:
                      - media_content_type: app
                        media_content_id: media-source://media_source
                - delay:
                    hours: 0
                    minutes: 5
                    seconds: 13
                    milliseconds: 0
              while:
                - condition: state
                  state: "on"
mode: single
Code for second automation:
alias: stopmp3
description: Stop music when the light goes off
  - platform: state
    entity_id:
    to: "off"
condition: []
  - choose:
      - conditions:
          - condition: state
            state: "off"
        sequence:
          - service: media_player.media_stop
            metadata: {}
            data: {}
              device_id: 538c2bef9b21fb879fbd6948f5da6f80
          - service: automation.turn_off
            metadata: {}
              stop_actions: true
              entity_id: automation.play2
          - service: automation.turn_on
            metadata: {}
            data: {}
mode: single
Hope this helps someone
You should be able to achieve your goal with a single automation. Set its mode to restart and configure its State Trigger to detect the light turning on and off.
alias: example
  - platform: state
    to:
      - 'on'
      - 'off'
      - 'off'
      - 'on'
condition: []
  - if: "{{ trigger.to_state.state == 'on' }}"
    then:
      - repeat:
          sequence:
                  media-source://media_source/local/04-Won't Fight Your War.mp3
              metadata:
                thumbnail: null
                media_class: music
                navigateIds:
            - delay:
                minutes: 5
                seconds: 13
          while:
            - condition: state
              state: "on"
    else:
mode: restart
That worked, thanks I should have RTFM…
