Hi David,
I’m having a very strange problem which I don’t understand at all that I’m hoping you might be able to shed some light on. Every night at either 00:47 or 01:47, the heat in my daughter’s room is getting turned off, and as far as I can tell, there’s nothing in anything I’ve configured that is doing it. I have searched and none of my automations or schedules ever turn the heat off anywhere, they always turn it to minimum 12 degrees. Could you possibly take a look at the below snippet of when it happens and tell me any idea you may have what could be causing it?? Thanks.
2020-09-07 00:43:26 DEBUG (MainThread) [homeassistant.components.evohome] Status = {'locationId': '3184115', 'gateways': [{'gatewayId': '2937956', 'temperatureControlSystems': [{'systemId': '4187037', 'zones': [{'zoneId': '4187036', 'temperatureStatus': {'temperature': 24.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 25.0, 'setpointMode': 'FollowSchedule'}, 'name': 'Living Room'}, {'zoneId': '4217766', 'temperatureStatus': {'temperature': 21.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 19.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-08T00:29:00+02:00'}, 'name': 'Dining Room'}, {'zoneId': '4217767', 'temperatureStatus': {'temperature': 20.5, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 17.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-08T00:29:00+02:00'}, 'name': 'Entrance'}, {'zoneId': '4217768', 'temperatureStatus': {'temperature': 21.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 21.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-08T00:29:00+02:00'}, 'name': 'Laundry room'}, {'zoneId': '4217769', 'temperatureStatus': {'temperature': 22.5, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 21.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-08T00:29:00+02:00'}, 'name': "Sebastian's Room"}, {'zoneId': '4217770', 'temperatureStatus': {'temperature': 22.5, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 5.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-08T00:29:00+02:00'}, 'name': "Sophie's Room"}, {'zoneId': '4217771', 'temperatureStatus': {'temperature': 22.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 20.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-08T00:29:00+02:00'}, 'name': 'Guest Bedroom'}, {'zoneId': '4217772', 'temperatureStatus': {'temperature': 22.5, 'isAvailable': True}, 'activeFaults': [{'faultType': 'TempZoneActuatorLowBattery', 'since': '2020-08-26T04:39:38'}, {'faultType': 'TempZoneActuatorCommunicationLost', 'since': '2020-08-29T14:06:37'}], 'setpointStatus': {'targetHeatTemperature': 21.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-08T00:29:00+02:00'}, 'name': 'Master Closet'}, {'zoneId': '4217773', 'temperatureStatus': {'temperature': 22.5, 'isAvailable': True}, 'activeFaults': [{'faultType': 'TempZoneActuatorLowBattery', 'since': '2020-08-26T04:51:10'}], 'setpointStatus': {'targetHeatTemperature': 21.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-07T22:29:00Z'}, 'name': 'Master Bedroom'}, {'zoneId': '4217774', 'temperatureStatus': {'temperature': 19.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 17.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-08T00:29:00+02:00'}, 'name': 'Garage'}, {'zoneId': '4217775', 'temperatureStatus': {'temperature': 21.0, 'isAvailable': True}, 'activeFaults': [], 'setpointStatus': {'targetHeatTemperature': 21.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-07T22:29:00Z'}, 'name': 'Office & Library'}, {'zoneId': '4217776', 'temperatureStatus': {'temperature': 23.0, 'isAvailable': True}, 'activeFaults': [{'faultType': 'TempZoneSensorCommunicationLost', 'since': '2020-08-25T19:45:28'}], 'setpointStatus': {'targetHeatTemperature': 21.0, 'setpointMode': 'TemporaryOverride', 'until': '2020-09-07T22:29:00Z'}, 'name': 'Master Bath'}], 'activeFaults': [], 'systemModeStatus': {'mode': 'DayOff', 'isPermanent': True}}], 'activeFaults': []}]}
2020-09-07 00:43:26 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=climate.sophie_s_room, old_state=<state climate.sophie_s_room=heat; hvac_modes=['off', 'heat'], min_temp=5.0, max_temp=25.0, preset_modes=['none', 'temporary', 'permanent'], current_temperature=23.0, temperature=21.0, hvac_action=idle, preset_mode=temporary, status=setpoints=this_sp_from=2020-09-06T21:30:00+02:00, this_sp_temp=21.5, next_sp_from=2020-09-07T06:30:00+02:00, next_sp_temp=23.0, zone_id=4217770, active_faults=[], setpoint_status=target_heat_temperature=21.0, setpoint_mode=TemporaryOverride, until=2020-09-08T00:29:00+02:00, temperature_status=temperature=22.5, is_available=True, friendly_name=Sophie's Room, icon=mdi:radiator, supported_features=17 @ 2020-09-07T00:30:02.310637+02:00>, new_state=<state climate.sophie_s_room=off; hvac_modes=['off', 'heat'], min_temp=5.0, max_temp=25.0, preset_modes=['none', 'temporary', 'permanent'], current_temperature=23.0, temperature=5.0, hvac_action=off, preset_mode=temporary, status=setpoints=this_sp_from=2020-09-06T21:30:00+02:00, this_sp_temp=21.5, next_sp_from=2020-09-07T06:30:00+02:00, next_sp_temp=23.0, zone_id=4217770, active_faults=[], setpoint_status=target_heat_temperature=5.0, setpoint_mode=TemporaryOverride, until=2020-09-08T00:29:00+02:00, temperature_status=temperature=22.5, is_available=True, friendly_name=Sophie's Room, icon=mdi:radiator, supported_features=17 @ 2020-09-07T00:43:26.838813+02:00>>
