Thanks for posting, this is what i am looking to build for a watertank… (just without the light).
I have only recently been introduced to ESPHome (have a lot of components running MQTT), and would like to build your solution. Could i please ask for your guidance and assistance which others could potentially benefit from as well.
I can work out how to get esphome onto the D1Mini (youtube is a lot of help here), and i am guessing the Template Sensor will slot into my configuration.yaml file. Is this all the config which is needed?
Could you please post a schematic of your wiring and the components you used, as i can see what look like two resistors on the breadboard which i need help with.
Thank you in advance for all of your help
Michael
